Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors Forums > AGP Turbo
Old 07-01-2007, 07:15 PM   #1 (permalink)
SRT-What?'s Avatar
Member Number: 10224
Default How to bolt AGP's manifold...
Is it normal that I can't have access to all the bolts behind the turbo flange and behind the wga flange ?
If yes : why is there some holes ?
If no : Is there a special method ?
thanks
SRT-What? is offline   Reply With Quote
Old 07-01-2007, 07:25 PM   #2 (permalink)
littlepvt's Avatar
Member Number: 3267
Trader Rating: (45)
Yes that is normal. You need to put studs in those locations and then use nuts with lock washer
DCR: 2.6 over 40 stroker, Pro series Head w/ Crane 18, Input Shaft, Intake manifold w/ Tial BOV, CP Ignition
AGP: GT3582R turbo kit
Mopar: Sway Bars, S3R CO, Ti Strut Bars,
Rage-Tek: LCA, TOB, Triple Fuel Pumps, 1000cc Inj 3/4 fork
Autometer: WB, Boost, Oil PSI, Oil Temp, EGT, FP
ClutchMaster: Twin Disk
AEM: EMS w/ 3.5 BAR sensor
JMB: 4in Intake, Hotside Hardpipe
Boomba: All 3 MM
littlepvt is offline   Reply With Quote
Old 07-02-2007, 02:39 PM   #3 (permalink)
Jon@AGP's Avatar
Member Number: 26404
Trader Rating: (66)
You will need to use the supplied studs with the manifold. You also will most likely need to slide the manifold out to about halfway on the studs to get a couple of the nuts started, then push the manifold all the way against the head.
Jon@AGP is offline   Reply With Quote
Old 07-03-2007, 12:46 PM   #4 (permalink)
SRT-What?'s Avatar
great..... And if no stud came with it ? (bought used) Can you just tell me what kind of stud it is ? (or post pics, whatever). I already have to go to a "bolt and screw" warehouse for something else....
(if you have some spare time... )
Old 07-03-2007, 01:11 PM   #5 (permalink)
Jon@AGP's Avatar
Trader Rating: (66)
They are M8x1.25 studs. If you would like to get a set directly from us just give us a call!
Page generated in 0.17743 seconds with 13 queries
