Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors Forums > AGP Turbo
Old 09-30-2005, 07:22 PM   #1 (permalink)
Member Number: 32157
Trader Rating: (12)
Default hooking up wg w/ no mbc
i have had it hooked up to stock line but not holding high enough. im sure this is a stupid ? if i hook it up like the directions just run a line from turbo to the wg. when they say use the green line i assume that just means run the hose from where the green line was on the turbo, not to actually use the green line ran from turbo to wg?
nohemi is offline   Reply With Quote
Old 09-30-2005, 08:26 PM   #2 (permalink)
Member Number: 7088
Trader Rating: (88)
AGP Wastegate Actuator Instructions - The Be-All End-All
adrenalineaiax is offline   Reply With Quote
Old 09-30-2005, 08:32 PM   #3 (permalink)
Trader Rating: (12)
what size line should i buy, or can i reuse the black rubber line that was hooked up to the factory wg.also i bought it used w/o the bleed do i really need it, if so how many holes should i poke in a vac line connector?
Old 09-30-2005, 08:40 PM   #4 (permalink)
Member Number: 7088
Trader Rating: (88)
man that thread answers all the qs thats why its the be all end all .. doesnt matter the size so long as u can hook it up to the nipple on the wga and the back of the turbo. no u dont need the bleed. its a ghetto bc.. either buy a nice dual stage bc or dont bother buying one at all
Old 09-30-2005, 08:50 PM   #5 (permalink)
shawnturbo's Avatar
Member Number: 23070
I have a peice of 3/16 tubeing from the nipple on the turbo to my boost controller "t". I cannot see or remember the size of of the size of the tubeing going to the WGA itself, hope this bit of half assed info helps!
THEN-292hp/342tq. 11.993@113.18True-Stockturbo NOW-500/510 11.25 @ 123 AGP hp61 bb .82ar s5 w/ S comp. housing,B&G reflash,LFS 60mm tb ,DASported intake mani.,Needswings dp ,M&H slicks, Boomba eng. & trans. mounts, PSI-FI traction bushings,traction bars,tien coilovers,Crower S2 cams,Fidanza gears,water/meth. inj.Nemo's hydr. tob,ACT 6puck ridgid,NDE tcs,D-TEC fc/bc & tuner/wideband,Walb.255,spoolboy mod,AGP return-RC750inj.
shawnturbo is offline   Reply With Quote
Old 09-30-2005, 09:14 PM   #6 (permalink)
Member Number: 7088
Trader Rating: (88)
well he can also pull the connecter thats going to the back of the turbo or wga in stock form and take that to auto zone to compare if he doesnt want a tight fit
Page generated in 0.15258 seconds with 13 queries
