Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendor Forums > AGP Turbo
Old 10-26-2009, 06:58 PM   #1 (permalink)
daniel427ss's Avatar
Member Number: 51325
Default ext. wasegate actuator flange n gasket
i bought a used turbonetics evo wastegate,(with 15# spring is that enough to hold 26 27+psi?) i will need a flange to weld up, n gaskets, how much? manifold-to-head gasket too if u carry them.
can u price everything individually plz. thank u very much
srt stock motor mounts 4 sale
bunch of 350z parts for sale, cp pistons .020over, eagle rods, headgaskets, heads, timingcovers, etc. etc.
daniel427ss is offline   Reply With Quote
Old 10-28-2009, 12:18 PM   #2 (permalink)
Jon@AGP's Avatar
Member Number: 26404
Trader Rating: (90)
The 14psi spring should be enough to support your desired boost.
I don't have the manifold to head gasket. That will be a part you can find at your dealer, or even reuse if yours does appears to be in good shape.
The wastegate flanges can be found here. Make sure to specify if you need a threaded or unthreaded flange:
AGP Turbochargers, Inc. :: Do-It-Yourself Parts :: Flanges and Gaskets :: TiAL 35/38, Turbonetics Evolution/Deltagate Flange
The wastegate gaskets can be found here:
AGP Turbochargers, Inc. :: Do-It-Yourself Parts :: Flanges and Gaskets :: AGP WG-38, TiAL 35/38, Turbonetics Evolution/Deltagate Gasket
Jon@AGP is offline   Reply With Quote
Page generated in 0.11016 seconds with 13 queries
