Quote: Originally Posted by
Jon@AGP
Do you know anyone with a manual boost controller just to see if it makes any difference?
Also, what gear are you testing it in? You need to make sure you are in 3rd gear, otherwise the car will not be under enough load to spool the turbo.
I can probably find a manual boost controller to borrow. However I have the ability to turn off this one and it acts the exact same way on the wastegate only.
I've been testing in 4th gear, because 3rd gear happens REALLY fast to be able to keep an eye on my boost gauge, water inj light, afr gauge, ect, ect ... oh yeah, and the road too LOL
Here's what happens in either 3rd or 4th though : I start down low at about 2800 rpms and go WOT. It SLOWLY climbs until it gets to about 4000 rpms and then shoots on up pretty fast until it reaches the target boost.
Thing is though, at 4000 when it really starts to spool up fast, I am WAAAAAY below the target boost ... like about 15 or 16 psi. It doesn't hit that target boost until about 5200 rpms.
I thought I should be at close to target boost at about 4000 rpms ... Isn't that what full spool means ?
