Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendor Forums > AGP Turbo
Old 09-14-2009, 07:04 PM   #1 (permalink)
Rhunter's Avatar
Member Number: 36794
Default Delta 44 Vs. T03/T04 3147
Ok guys which one, and why?
I think I'm starting to tire of nitrous, but I still want that power and torque.
- Car is driven on weekends, and used on the track (still learning to drive)
- eventually want 11 sec street car without stripping the holy hell out of the interior (at least not yet), I don't have a trailor so the car has to be driven 72 miles to and from the track.
Ok discuss.
Old 09-14-2009, 07:12 PM   #2 (permalink)
conroy9940's Avatar
Member Number: 46401
Trader Rating: (114)
you can't go wrong with either turbo IMO... i think they are both great for what they do and will get you in the 11's no problem.
Pittsburgh Penguins 14-8-0 28 points
Old 09-14-2009, 08:43 PM   #3 (permalink)
Kason23's Avatar
Member Number: 34502
Trader Rating: (20)
Very similar power wise. With the D44 spooling a little sooner then the .63 3147. If your just wanting 11's a D44 on pump gas can do that no problem IMO. As so will a 3147. Add meth and you can have a high 400wtq monster lol
Im actually thinking of selling mine and going bigger. And I dont even know why
Tuned By TDSAaron!!
My Goal: 100+Mph in the 1/8
Kason23 is online now   Reply With Quote
Old 09-14-2009, 08:53 PM   #4 (permalink)
Rhunter's Avatar
Thanks for the reply's guys.
Correct me if I'm wrong but if I go with the T03/T04 kit, I would have more options for upgrading the turbo charger later on. Am I right or did I mis-read something?
Old 09-14-2009, 08:55 PM   #5 (permalink)
Kason23's Avatar
Trader Rating: (20)
With any AGP kit you can swap turbos easily. Almost all there turbos bolt up to there manifold
Old 09-14-2009, 10:40 PM   #6 (permalink)
T8NTKLR's Avatar
Member Number: 55697
Trader Rating: (20)
the d44 is an awesome turbo. i dont have much to refer it to since this is my first big turbo but i can say this it is almost as fast as my car was when i was spraying my car with a 75 shot on a bolt on stage2 set up. spool is around 3200 rpm. woith the mods that i do have agp hard pipes mpx exhaust injen SRI the d44 turbo kit and it is agp/sct tuned with a 255 pump and 750 injectors. i put 100% 110 octane gas in my car turned the boost up to where i thought would be 24 psi but was actually 26 psi did a third gear pull from 55 and it just blew the tires off suprisingly i didnt get any knock on my scan guage and ran a 11.7 afr at red line the fastest my car has everr felt even with nitrous. but were i run my car from day to day around 19 psi i would say its about there with my nitrous set up from last year. and it dosent cost me 50 bucks every weekend to go that fast. wise decision going big turbo imo
05 red srt-4
AGP D44 kit, AGP hard pipes W/hks limited black, AGP motor and trans mounts, Mopar clutch, MPX3", AEM UEGO, Scan Gauge, Injen SRI, PnP TB, APEXi turbo timer, Maddog80%, Greddy catch can, PTP CV, MSD 2-step W/slicks for sum nasty 60'
soon AGP/SCT tuned, walbro 255, and 750cc injectors
nitrous FTMFW
T8NTKLR is offline   Reply With Quote
Old 09-14-2009, 10:46 PM   #7 (permalink)
lyncoo's Avatar
Member Number: 43166
Trader Rating: (92)
both make pretty much the same power. 3147 maybe a little more but the d44 would spool faster imo, i could be wrong
AGP S256 FS
Old 09-15-2009, 06:01 PM   #8 (permalink)
aww sheet's Avatar
Member Number: 20431
Trader Rating: (31)
you can drive mine once i install my fuel components. i have a 3147
View Modifications
Old 09-15-2009, 06:12 PM   #9 (permalink)
SonnySrt-4's Avatar
Member Number: 34315
Trader Rating: (10)
d44, thing spools quick! Nearly no lag at all and you get great instant trq curve. I think it a great turbo for this car.
Edited by Inzanesrt4
Agp s3d-44lb turbo kit
38mm TurboSmart Wga
3inch bdj's catless down pipe dumped exhaust
BFMIC
N2MB Boost box (GET ONE!!!)
D/O Meth/Alchy injection m5
DSP tuner
800cc injectors
HKS bov and hard pipe
SonnySrt-4 is offline   Reply With Quote
Old 09-16-2009, 12:19 AM   #10 (permalink)
bene's Avatar
Member Number: 53801
Trader Rating: (40)
d44, IMO a better turbo. it makes more tq, spools sooner, and likes our powerband more.
3147 is kinda outdated, i wouldnt even think about bolting one of those to my car anymore.
bene is offline   Reply With Quote
Old 09-16-2009, 01:21 PM   #11 (permalink)
Jon@AGP's Avatar
Member Number: 26404
Trader Rating: (90)
The compressors are close in size and max power output. The delta 44 will spool a bit faster due to it being in a .48 a/r turbine housing. The 3147 will probably make a bit more power up top due to the larger .63 a/r turbine housing.
Jon@AGP is offline   Reply With Quote
Old 09-16-2009, 06:44 PM   #12 (permalink)
aww sheet's Avatar
Trader Rating: (31)
yeah its so out dated that agp brought it back. i guess 50 trims are out dated too.
Old 09-16-2009, 06:46 PM   #13 (permalink)
Jon@AGP's Avatar
Trader Rating: (90)
We are constantly trying to improve upon what is currently available, so we are always coming out with new combinations.
Old 09-21-2009, 11:03 PM   #14 (permalink)
jessebeachusmc's Avatar
Member Number: 70610
and that why you guys are the best:
im probably going to buy a d44 sometime in the future to swap out with my s256 just for shits and giggles. so whenever i want the quicker spool ill put the d44 on and whenever i want my 500hp beast ill swap my s256 back on.
AGP borg warner s256 powered
jessebeachusmc is offline   Reply With Quote
Old 09-22-2009, 01:07 AM   #15 (permalink)
bene's Avatar
Trader Rating: (40)
50 trims a bad ass turbo, might not be the newest technology but its proved to be great.
3147 not so much.
ill let numbers speak for themselves
Page generated in 0.21758 seconds with 13 queries
