d44 outlet diam
I am running a Delta 44 and the stock worm gear clamps aren’t cutting it. What’s the outlet diameter of the turbo, so I know what size t-bolts I need? Also do you know what size I would need for the stock charge pipe?
GO FAST PARTS
Stock PCM
AGP 44# delta
Diablo predator
Dtec FC
FIC 625cc injectors
AGP returnline
PTP 55mm TB
PTP check valve
ED hardpipes w/ HKS BOV
Maddog STS 72%
AGP motor mounts
Zeitronix ZT2 wideband
Needswings DP (no cat)
180 thermostat
Bwoody H-brace combo
Bwoody Trans mount
