Quote: Originally Posted by
Flash_srt-4
Ok he wanted me to ask u a couple questions.
1. To silicone it would he loosen the bolts about an half inch then apply it inbetween or around it.
2. What kind of silicone is going to be able to with stand that amount of heat and pressure?
Again man thanks for all ur help on this.
1. I would make sure the housing is clocked the way you want it. Mark the housing with it on the turbo the correct position. Take the housing completely off, and run a really smooth SMALL layer of silicone around the mating surface of the housing. Really small layer.
2. Grey RTV will work just fine. It's really not that hot in that area.
