what is the best form of boost control on a big turbo (s256 in my case) with external wg? I know its easiest to use a manual controller but which one works best, and is easiest to adjust?
i have the GReddy Profec-B SPEC 2. you can have it set up with high and low boost setting. low boost for 1 & 2 gear then high for the rest. i dont know if it is the best since it is the only one ive ever had... but i like it
I never used the N2MB Boost Box, but Gear Dependent Boost is the way to go.
I had the AVC-R which, admittedly is a PITA to get setup right. The N2MB box looks to do the same thing, but much simpler to get setup right and A LOT cheaper too. If I were setting up a car now, the N2MB Boost Box is probably the way I'd go.
I use a Halman Pro RX MBC with cockpit cable and it isn't too bad. Way better than some of the other MBCs that I have used in the past. an EBC would be a better way to go and if I was to go with one I would probably try the N2MB Boost Box. The WOT box and 2 step they made were great, I would love to see how the Boost box would work on my car as well.
