Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendor Forums > AGP Turbo
Old 08-24-2005, 08:44 PM   #1 (permalink)
wfosrt's Avatar
Member Number: 2499
Default anyone running S2 w/ toys+650cc injectors+agp turbo kit?
Well, Iam starting over again and will be buying another agp turbo kit for my 05' shortly and was thinking about getting s2 w/ toys used and running 650cc injectors and 50trim at like 17psi. Wouldn't this combo be good for like ~370whp.
03' BLACK AGP 3147 Turbo kit. AGP 750cc fuel kit, AGP Spark Plugs
(14.5psi)297WHP/289WTQ
RIP: 6/5/05
94' EJ1 (d16z6 turbo)
wfosrt is offline   Reply With Quote
Old 08-24-2005, 08:48 PM   #2 (permalink)
Soldier101's Avatar
Member Number: 37
you can run 17 lbs on stage 2 injectors, your set, you should net around there
Mike Pruett
Member #37
MODS: Stock.......JUST KIDDING!!
Soldier101 is offline   Reply With Quote
Old 08-24-2005, 08:58 PM   #3 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (50)
this is the best way to go. GET the 650rc'ss and let the computer do all the tunnng for you. Stage 2 will correct fuel with bigger injectors. it works really well for a guy near me but he has a returnline and 750's. stage 2 no toys loves big turbos trust me.
reed32 is offline   Reply With Quote
Old 08-24-2005, 09:01 PM   #4 (permalink)
wfosrt's Avatar
Member Number: 2499
yeah, I know S2 loves big turbos, I was running just S2 and the 3147 at 14.5psi when I made 297whp
Old 08-26-2005, 10:02 PM   #5 (permalink)
srt4ninja's Avatar
Member Number: 22660
so you can you just get the stage 2 no toy's (why can you not use toys by the way with this setup)and a 50 trim kit and you can just let the computer do all the tuning for you? I know that stage two has 682cc injectors , so theres pleanty of fuel, but up to what kinda hp and what kinda psi????
srt4ninja is offline   Reply With Quote
Old 08-26-2005, 10:20 PM   #6 (permalink)
wfosrt's Avatar
Member Number: 2499
you can run s2 w/o toys and an agp turbo> thats what I ran at 14.5psi and made 297whp.
Old 08-27-2005, 05:31 PM   #7 (permalink)
srt4ninja's Avatar
did you have too tune anything at all? what are your mods?
Old 08-27-2005, 05:47 PM   #8 (permalink)
guygettnby's Avatar
Member Number: 6055
Trader Rating: (57)
i wouldnt say that stage 2 loves bigger turbos......it kills your power when you really start to up the boost. i know this for a fact first hand. it works rather well at lower boost levels, but it yeilds less power then a stage 0 car with same setup.
guygettnby is offline   Reply With Quote
Old 09-23-2005, 03:30 PM   #9 (permalink)
AtlSrt4's Avatar
Member Number: 25594
but, what if you use a mapclamp? & prevent the PCM from seeing all that boost. That way, you could up the boost until you reach the desired AFR & then just use the clamp. Then the PCM would not pull timing. But, also - stage 2 is designed to Spike 17-19psi (correct me if I am wrong) and hold about 17 to redline. So, this would be more than enough to lean out the S2 682cc injectors. My question to AGP guys is - what kind of power figures would be reasonable to expect if we went this route - considering that all other supporting mods have been done (intake, exhaust, intercooler)
AtlSrt4 is offline   Reply With Quote
Old 09-23-2005, 07:53 PM   #10 (permalink)
AtlSrt4's Avatar
and after some more researching - I've found the answer. It is just that there is so many posts now & it takes forever to get to the relevant stuff. But, for those that were wondering the same thing I was - the answer is that - 50 trim can be used on s2 (with s2 PCM & injectors) & would be good for 320-340Hp. Although, when I was on the phone with AGP the other day - number 370 Came up. So, I will most likely start with just the turbo swap, too - and then later on do the fuel system upgrade. That way, butt dyno will be happy for a long time. Only Question I DO have and really could not find answer to anywhere - is how mu TQ would I see with that setup? (only s2 without AGP fuel kit)
Old 09-23-2005, 09:39 PM   #11 (permalink)
Nick@AGP's Avatar
Member Number: 11546
Probably about the same. 340/340. Thats about all the fuel you have with going to larger injectors.
Nick -
Do Not PM me. Email sales@agpturbo.com or call.
AGP Turbo
Nick@AGP is offline   Reply With Quote
