AGP UHP 1/8" NPT fitting? - Dodge SRT Forum
post #1 of 25 (permalink) Old 05-08-2010, 09:49 PM Thread Starter
Quoted: 0 Post(s)
Hey guys. Having a little trouble finding exactly what I need here.
I have the AGP UHP w/ HKS BOV. It's all installed and working great, but I've decided to setup the vacuum lines to (mostly) their stock configuration in preparation for my SCT PRP. In order to do this, I need to run the red line. I know I need a "1/8" NPT pipe fitting", but I find all kinds of fittings that could almost fit this description, so I'm unsure exactly what I need.
Found a couple that look promising..
Holley Performance Products Brass Hose Connection Adapter*16244NOS
Pipe Fitting 1/8 NPT x 0.25 Straight Hose Barb
NOS 16244ANOS Pipe Fitting Brass Hose Connection Adapter 1/8 NPT - 0.25 Hose
Am I on the right track? Seems like a simple thing, but I want to make sure before I order anything.
05' Flame SRT-4
Stage 2, ACT 6 puck w/ streetlite FW, SCT PRP, N2MB WOT/2-step, K&N CAI, Bwoody motor/trans mounts, AGP hardpipes w/ HKS BOV, MPx CC, NGK 4306's @ .34, Granatelli wires, Granatelli coil, 180 tstat, AGP WGA, Tein type S susp, AGP Valve cover breather, Maddog STS, MPx 3" turbo back, Carbon by design hood, Maxiim 17 inch rims, DCR 255 pump
Mrock is offline
post #2 of 25 (permalink) Old 05-08-2010, 09:54 PM
gglaeser12's Avatar
Quoted: 0 Post(s)
I have the Holley one (bought from that same link) in my garage. Never put it on, but I *think* it's the right one. I'll try to check Monday on my day off.
If I agreed with you we would both be wrong.
gglaeser12 is offline
post #3 of 25 (permalink) Old 05-08-2010, 10:07 PM Thread Starter
Quoted: 0 Post(s)
I'd appreciate it greatly..
05' Flame SRT-4
Mrock is offline
post #4 of 25 (permalink) Old 05-10-2010, 10:20 AM
2011 Calendar Car
NoisufnoC's Avatar
Quoted: 4 Post(s)
Dont they have these kind of things at Home Depot or Lowes?
I remember the days of...
...most of you weren't born yet.
|| Mod List || RIP Mod List || (Re)Build Thread ||
|| Blog || Mr. November #3 ||
NoisufnoC is offline
post #5 of 25 (permalink) Old 05-10-2010, 10:48 AM
New Member
Jon@AGP's Avatar
Quoted: 0 Post(s)
To put a nipple in the pipe, you jsut need a 1/8" NPT fitting that adapts to the hose barb size for the vacuum line you plan to run.
Jon@AGP is offline
post #6 of 25 (permalink) Old 05-10-2010, 12:12 PM Thread Starter
Quoted: 0 Post(s)
Thanks. Just wanted to double check. I'll head to lowes and check their selection out. If not I'll just order online.
05' Flame SRT-4
Mrock is offline
post #7 of 25 (permalink) Old 05-11-2010, 07:57 AM
Ben@AGP's Avatar
Quoted: 5 Post(s)
Home Depot has them.
WEBSITE | EMAIL | YOUTUBE | FACEBOOK | 480-983-6083
Ben@AGP is offline
post #8 of 25 (permalink) Old 05-11-2010, 07:17 PM
gglaeser12's Avatar
Quoted: 0 Post(s)
Sorry it took so long to reply.
Like I said I ordered the first one from Holley. It threads into the pipe, however the 3/16th barb end is too small for the factory "90 degree boot" on the red vacuum line. If you snip the red line and slide a spare piece of vac line over it, you can use that brass fitting. If you are dead set on keeping the factory lines factory you will need the same thread but with a bigger barb. I would assume like the other two links you posted.
My local Homo Depot and Lowes did not have the 1/8 NPT thread but offered to order them.
Then again, my local HD also "can't" cut plywood, Don't seem to have the correct toilet handle, and suggested I put 5 6x8 wood fence panels on top of my Expedition.
Hope it works out for you.
G
post #9 of 25 (permalink) Old 05-11-2010, 10:20 PM
Ben@AGP's Avatar
Quoted: 5 Post(s)
G
Wow, Home Depot FTL.
I'll try and snap a pic next time at Home depot for a fitting that will fit. Another place you could check is a local industrial hydrolic shop. They will have NPT to tube/barb connectors.
Ben@AGP is offline
post #10 of 25 (permalink) Old 05-12-2010, 04:21 AM Thread Starter
Quoted: 0 Post(s)
I knew the 1/8" NPT would fit in the threads, but that barb is the part I was concerned about. Thanks for checking gglaeser..
I'd ideally like to leave the boot on there (just incase I ever need to return to stock completely). I'm off tomorrow and will head out to see what I can find. I'll probably bring the red line with me just to make it easier.
Thanks ben..if I get there before you do I'll snap one and post here for others.
05' Flame SRT-4
Mrock is offline
post #11 of 25 (permalink) Old 05-13-2010, 02:18 PM Thread Starter
Quoted: 0 Post(s)
Went to home depot and got the 1/8" NPT to 3/16"..definitely too small as said before, but that's all they had. I put a piece of 7/32" (I think?) vacuum hose over the barb, zip tied it, and put a step-down connector in the end of that, then the stock red line over that..not the cleanest method but it should work fine.
I'm only using it as a temporary fix, I can now verify that ideally you want 1/8" NPT x 1/4" barb. The second and third links I posted should work fine. I'll be ordering one of them, and use my temp workaround in the meantime. Took a pic, will post in a few.
Edit: Sent the pic to my e-mail from my phone, it's taking forever to arrive. I'll post it later..
05' Flame SRT-4
Mrock is offline
post #12 of 25 (permalink) Old 05-16-2010, 10:30 AM
gglaeser12's Avatar
Quoted: 0 Post(s)
Just found this 15 minutes ago.
NAPA FTW.. part 90-547. 1/8th NPT Brass fitting that fits 1/4 hose labeled Tire Hardware. think it was $2.49. It fits the factory red hose "boot" perfect... and to think I paid $20 for the holley one..
I'm gonna make sure it screws into the AGP pipe in a few minutes.
G
post #13 of 25 (permalink) Old 05-16-2010, 11:02 AM Thread Starter
Quoted: 0 Post(s)
G
Nice! Thanks. I was going to be lazy and order a $15 one I found online, really glad I didn't. Good lookin' out
05' Flame SRT-4
Mrock is offline
post #14 of 25 (permalink) Old 05-16-2010, 02:14 PM
gglaeser12's Avatar
Quoted: 0 Post(s)
Fits perfect. Well as perfect as the plug that I pulled out of the AGP pipe. I say that cause the plug sits flush with that "bung" it's in, however it's only a few threads deep. You'll see what I mean when you pull that plug out. I didn't tighten that brass fitting too much for fear of cross threading the thing. Seems to be working well.
Only bad thing about NAPA is their hours on Sunday. Good luck man.
G
post #15 of 25 (permalink) Old 05-16-2010, 02:34 PM Thread Starter
Quoted: 0 Post(s)
G
It's all good, I'm stuck at work till this evening anyways! Appreciate checking for me. I'll pick one up my next day off and get it hooked up hopefully.
05' Flame SRT-4
Mrock is offline
User Tag List
Linear Mode Linear Mode
