AGP Turbo Kit Bolt Size Chart
Studs for the Manifold to Head - M8x1.25x40
Cast Manifold to Turbo - 3/8-16x1
Cast Manifold to Wastegate - 5/16-18x7/8
Turbine Housing to O2 housing - M8x1.25x25
If you are going to source these parts from your local bolt supply house, make sure that all your standard bolts are Grade 8, and all your metric bolts are class 10.9.
For all the lock washers, they must be "HIGH ALLOY" or they will not keep their tension on the bolt head.
