Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > AGP Turbo
Old 06-15-2008, 03:07 PM   #1 (permalink)
srtras's Avatar
Member Number: 52121
Default AGP SCT tune on E85
anyone had a tune made with E85? can this even be done? if anyone has info on this please post here. thanks
gt30r, AGP SCT tune and all supporting mods
srtras is offline   Reply With Quote
Old 06-15-2008, 05:23 PM   #2 (permalink)
BoostingSnail's Avatar
Member Number: 27440
Trader Rating: (10)
haha..why would you want to do such a foolish thing?
Naylor Racing<---Check Us Out! AGP TURBO!!!
AGP Stage 3 Complete Delta 47lb(beta tester)Kit-AGP 38mm Wastegate-750cc Inj.-255 Walbro-SCT Flash-3" MPx dual exit w/ catless downpipe-AGP standard intercooler/ Slowboy Racing Crashbar-Tial BOV-AEM Cold Air-MSD Wires-180* Thermostat-Solid Motor&Trans Mounts-Koyo Radiator-AEM Wideband-Aeroforce Interceptor
Coilovers, 26x8 Hoosiers, & Clutch coming soon!!
BoostingSnail is offline   Reply With Quote
Old 06-16-2008, 07:20 AM   #3 (permalink)
uncutfourplay's Avatar
Member Number: 47331
what are the advantages of running E85 and bump for interest
spendin money that I don't have to buy parts that I don't need to impress people that I don't know
Agp Stage 3D-44lb/min wheel, AGP SCT custom tune, exhaust depot beast bfmic, south bend stage 3 clutch, bdj's ported tb and gasket matched intake mani, DeatschWerks 650 injectors, AEM short ram intake, bdj's 3" dump, Tial wastegate 19-22, Hallman MBC w/Incabin control, hks bov w/ agp pipe, return line, walbro 255 pump
uncutfourplay is offline   Reply With Quote
Old 06-16-2008, 09:47 AM   #4 (permalink)
NoisufnoC's Avatar
Member Number: 136
E85 has an octane level of about 105, however you have to run about 30% more than regular gasoline.
Its a cheaper alternative to race fuel, but wont save you $$ on premium gas.
bump for interest
omgz!! i haz mods!!
NoisufnoC is online now   Reply With Quote
Old 06-16-2008, 01:05 PM   #5 (permalink)
srtras's Avatar
cuz AGP says above 22psi you should have race gas in with the SCT tunes... so with E85 being 105 oct and being half the price or more of race gas this would be a huge money savings
Old 06-16-2008, 02:38 PM   #6 (permalink)
Trader Rating: (10)
My comment was sarcastic...it is a great idea...I have brought it up in a past conversation with Ben. The octane is higher with E85 over pump gas, however you need to run it 'richer' than regular pump gas. Im sure timing is different as well. Not sure if the FlexFuel vehicles out there have special fuel lines...E85 might 'eat' away at the lines differently than pump gas....that is just a thought....i dont even know if it is true or not.
Old 06-16-2008, 02:46 PM   #7 (permalink)
NoisufnoC's Avatar
Member Number: 136
theres a number of threads in the fuel section on this topic, and a ton of knowledge on DSM and EVO forums about E85.
You have to run about 30% more fuel delivery, because it burns stoic at about 9:1 (vs. 14.7:1 gasoline).
however, since its basically 105 octane you can run a shit ton more timing and boost.
how much is race gas in your area? Here, our 100 octane unleaded pump is $5.99 / gal. I was seeing E85 prices in the high $3 range, about $3.75 or so...do a little math (3.75 * 1.30) = about $4.88 / gal. Better price than 100, and a better fuel too.
Old 06-16-2008, 02:48 PM   #8 (permalink)
Trader Rating: (10)
Support your local farmers too!!..haha
Old 06-16-2008, 06:09 PM   #9 (permalink)
srtras's Avatar
in duluth minnesota theres one gas station that sells 110, it was 6.50 per gallon last summer... havent been there yet this year but im sure its more and e85 is right around 3.65
Old 06-17-2008, 10:08 AM   #10 (permalink)
Ben@AGP's Avatar
Member Number: 333
Trader Rating: (75)
You're forgetting the cost involved with an extra fuel pump, fuel lines, 1000+ cc injectors, peak hold box, etc. THere's a little more involved than just throwing some corn gas in a car and expecting 105 octane worth of fuel.
Sales Questions sales@agpturbo.com
Email Me Directly ben@agpturbo.com
Please Do NOT PM Me
www.agpturbo.com
Phone 480-983-6083
Fax 480-671-5665
Ben@AGP is offline   Reply With Quote
Old 06-17-2008, 10:14 AM   #11 (permalink)
NoisufnoC's Avatar
Member Number: 136
depends on the fuel requirement. there's guys in the evo world running single walbro 255's and big injectors on smaller sized turbos / stock turbos.
you can get plug and play, larger than 750cc injectors for the SRT-4.
on most people's DTEC type tunes for 750cc's on a SRT-4 they have about -30% correction. I wonder what that same car would do w/o any correction on E85. If I had the resources, I'd like to try this fuel. But my car can't be down for extended periods of time right now, and I dont have the SCT PRP.
Old 06-17-2008, 10:19 AM   #12 (permalink)
NoisufnoC's Avatar
Member Number: 136
would i be correct in saying that 750cc injectors at 50psi of fuel pressure are actually flowing about 805cc's?
Old 06-17-2008, 10:22 AM   #13 (permalink)
Ben@AGP's Avatar
Member Number: 333
Trader Rating: (75)
And if I wanted to make 375-400whp on my evo, I would just tune it right on 91 octance.
I am aware, and they work so wonderfully.
With zero correction, you'd be able to run around 15psi max before you max out the map sensor voltage. So 15psi on any turbo is not going to be any real power.
I'm not trying to argue. I know all the benefits of E85, but for most of the world it's certainly not worth it.
Old 06-17-2008, 10:25 AM   #14 (permalink)
Ben@AGP's Avatar
Member Number: 333
Trader Rating: (75)
sure, but why? They are still 750cc injectors whether you run them at 10psi of fuel pressure or 100psi of fuel pressure.
Old 06-17-2008, 10:27 AM   #15 (permalink)
NoisufnoC's Avatar
Member Number: 136
I'm not trying to argue either. It takes a hefty fuel system to make real power on E85.
It just seems like such a taboo subject in the SRT-4 community.
» Search Used Cars
