Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > AGP Turbo
Old 05-08-2008, 12:52 AM   #1 (permalink)
joneSRT's Avatar
Member Number: 58384
Default AGP SCT feedback???
Hi, I would like to here some feedback about the SCT tune here pls??
I have one with my 50 trim and i love it!!! The car run very good.
My wideband is fuck, so i dont know how much AFR i run, do you know ben or jon what is the target of each 3 tune 1=lean, 2=std, 3=rich???
I run at 15 and 21 psi.
thanks
50 Trim .48 A/R with AGP SCT tune.
joneSRT is offline   Reply With Quote
Old 05-08-2008, 10:42 AM   #2 (permalink)
Jon@AGP's Avatar
Member Number: 26404
Trader Rating: (64)
I would strongly suggest having your wideband fixed so you can keep an eye on how the car is running.
For part throttle and closed loop the air fuels will be jumping around in the 13-14-15 range.
Under wide open throttle in full boost you should be seeing no leaner than mid 11's.
Jon@AGP is online now   Reply With Quote
Old 05-08-2008, 03:45 PM   #3 (permalink)
joneSRT's Avatar
Today i see 5 and 6 KR on my aeroforce gage????
Old 05-08-2008, 03:56 PM   #4 (permalink)
quickshift's Avatar
Member Number: 55168
Trader Rating: (29)
subscribed to see feedback.....
BEST ET: 12.68@110 stg 0, stock turbo, stock intercooler, pump gas, & no meth
MODS ADDED SINCE THIS RUN: AGP BB .50T with all supporting mods
quickshift is offline   Reply With Quote
Old 05-08-2008, 04:17 PM   #5 (permalink)
SRTie4k's Avatar
Member Number: 45499
Trader Rating: (31)
I'm getting mine tomorrow, so I'll let you know what I think this weekend
SRTie4k is online now   Reply With Quote
Old 05-08-2008, 09:13 PM   #6 (permalink)
csufdrew's Avatar
Member Number: 1843
it sucks, you'll hate the shit out of it!
i think you should sell it, ASAP!
ps-if your knocking that much, dont go WOT and find the problem
some Q's:
1. is this the first flash?
2. why are you going WOT if your WB is broken? thats a death wish.
S3 powered
AGP
SCT tuned
1/8 mile: 91.22 mph on the 3rd pass with this setup
csufdrew is offline   Reply With Quote
Old 05-08-2008, 11:02 PM   #7 (permalink)
Ant
Ant's Avatar
Member Number: 2834
Thank you for posting your feedback......Let hear more!
AGP 50 Trim
Stage 1 AGP SCT FLASHED
NGK plugs gapped .35
HP Racing/ Magnaflow 3" turboback
ED Hard Pipes w/Greddy Type S BOV
Accel 300+ RED Spark wires
Spearco BIG FMIC
EMANAGE / E01 / LM1 / FPR / Deatchwerks 750cc
injen intake
180 themo
Clutchmasters Stage 3
Bwoody Traction Bars
PTp Check valve
Aerforce/AAronneon Interceptor Scan Gauge
Ant is offline   Reply With Quote
Old 05-09-2008, 06:36 AM   #8 (permalink)
SRTie4k's Avatar
Trader Rating: (31)
some Q's:
Why do you hate it?
Old 05-09-2008, 07:35 AM   #9 (permalink)
csufdrew's Avatar
Member Number: 1843
it was a joke.
your car isnt going to run 100% the first time you flash the car. Kevin needs your feedback on fuel trims, timing and AFRs (cause every car is different) to get your car dialed in.
My car is tuned pretty damn well right now on both my pump gas map and race gas map. Im sure I could add a couple more degrees of timing on my race gas map but Im playing it safe. you'll be happy, trust me! it just takes a lil patience.
just dont be one of those guys that flashes it once, takes it to the dyno the same day and post up results and comment on how it sucks and doesnt make the power it should.
Old 05-09-2008, 08:11 AM   #10 (permalink)
str5010's Avatar
Member Number: 34460
Im one of those guys who flashed it about 10 times, took it to the dyno twice, and now I wonder why it's not making the power it should but I dont believe that it is something wrong with the ECU flash. Something is causing my ECU to see phantom knock and we are just trying to figure out what it is. The other day at the track my scan gauge saw 5-6 KR on 2 gallons of 93 octane and 2 gallons of c16 race fuel. I dont think that is possible.
But anyway, the ECU flash is awesome and makes tuning easy. Part throttle tuning is dead on with the first flash and only small adjustments are needed for WOT to be dialed in. It is amazing what Kevin can do to the tune through email/phone conversation.
str5010 is online now   Reply With Quote
Old 05-09-2008, 09:07 AM   #11 (permalink)
can't stop spinning's Avatar
Member Number: 9183
That doesn't sound good for me. My car ALWAYS see's knock, even when there isn't any. In a way it's good though, as it keeps my timing lower.
I'm really close to pulling the trigger on this, but your post is making me a little nervous. With my car, full of c16, and running only 17lbs of boost, I'll still see 3-5 KR, and that's with timing only in the mid 20's.
If my car was really knocking as bad as my scan gauge says it is. I'd have blown my engine two years ago.
100% stock engine, stock head, cams, blah blah blah
1st srt in Canada to get kicked off the track
can't stop spinning is offline   Reply With Quote
Old 05-09-2008, 09:18 AM   #12 (permalink)
NoisufnoC's Avatar
Member Number: 136
maybe its time for a new knock sensor?
omgz!! i haz mods!!
NoisufnoC is online now   Reply With Quote
Old 05-09-2008, 10:34 AM   #13 (permalink)
Member Number: 9183
but why? I'd rather my timing be in the low-mid 20's, then in the high 20's, or even low 30's.
Old 05-09-2008, 10:38 AM   #14 (permalink)
Member Number: 63534
x1,000,000
Drastic_Said is offline   Reply With Quote
Old 05-09-2008, 10:54 AM   #15 (permalink)
MonsterLemon's Avatar
Member Number: 48761
Trader Rating: (42)
False knock? My car knocks anywhere near 11's it likes to be 10.8-10.9 on pump
MonsterLemon is online now   Reply With Quote
