Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > AGP Turbo
Old 05-15-2008, 09:04 PM   #1 (permalink)
Wheels & Tires Moderator
evo77's Avatar
Member Number: 1346
Default AGP manifold dilemma...
I've got the 1st gen log manifold. I've had on and off leaks at the wastegate flange for a few years. Last year I had a leak because the gasket was shot. As I was removing the wg the outer bolt head snapped forcing me to take it to a local shop to have them extract the broken bolt. They ended up trimming the manifold and had to make due with this...
Its been find until recently where it started leaking again. Took it all apart and replaced with a new gasket. Still leaks.
I don't think there is enough torque on that end bolt to get the wg clamped down good. You can't see in the pic but that bolt is slightly bent so that it fits from underneath. And half of the head is chopped off to clear the manifold.
What are my options?
I'd like to avoid having to purchase a new manifold. Would the high temp silicone gasket paste caked around the base help with sealing up the leak?
Old 05-15-2008, 10:10 PM   #2 (permalink)
bitts's Avatar
Member Number: 29842
Trader Rating: (57)
No silicone man.
The mani will dry that shit soooo quick man.
Mani 1k* > Silicone 600* depends
AGP3147 Powered 414hp/489tq tuned by bitts
bitts is online now   Reply With Quote
Old 05-16-2008, 11:16 AM   #3 (permalink)
Jon@AGP's Avatar
Member Number: 26404
Trader Rating: (64)
To start I would suggest replacing the bolt with a new one if it is bent. Also make sure you are using anti seize on the bolts to help prevent them seizing in the manifold on future removal of the wastegate, turbo, etc.
If you are unable to get proper torque on the bolt that would definitely aid in your leak as well.
Jon@AGP is online now   Reply With Quote
» Search Used Cars
Page generated in 0.20890 seconds with 11 queries
