Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > AGP Turbo
Old 05-14-2008, 04:23 PM   #1 (permalink)
SRToc Member
Pit Viper's Avatar
Member Number: 339
Trader Rating: (60)
Default AGP 50-trim, SCT tune numbers
Just got back from the dyno tuning in my cams.
AGP 50-trim
AGP SCT tune
ported head
crane 14's
water injection
the usual bolt-ons
I just installed my ported head and crane 14's, so I had Kevin give me a richer map (my wideband is dead, so I didn't know what it was doing), then tweaked it on the dyno with my dtec, and will have Kevin get me a new map based on the dtec settings (the way it should be done )
20 psi
eVilcreations sold me a POS unfixable turbo.
Old 05-14-2008, 05:37 PM   #2 (permalink)
Turbolag87's Avatar
Member Number: 6491
full boost by 3600rpm not bad for 20psi, how much timing were u seeing?
AGP WGA @ 16PSI @Redline (blue line
Rage 3" Downpipe with 3" 02 housing
Borla CatBack, Returnline
Snow Performance Stage II Water/meth injection
Best time : 12.38
Best MPH : 111.8
Soon to be a Stage 3 47lbs/wheel monster
Turbolag87 is offline   Reply With Quote
Old 05-14-2008, 06:29 PM   #3 (permalink)
Ben@AGP's Avatar
Member Number: 333
Trader Rating: (72)
Curious how you see full boost by 3600rpm.
Good numbers Aaron.
Sales Questions sales@agpturbo.com
Email Me Directly ben@agpturbo.com
Please Do NOT PM Me
www.agpturbo.com
Phone 480-983-6083
Fax 480-671-5665
Ben@AGP is offline   Reply With Quote
Old 05-14-2008, 06:37 PM   #4 (permalink)
Turbolag87's Avatar
Member Number: 6491
Good numbers Aaron.
DO tell when do you see full boost at?
Old 05-14-2008, 07:20 PM   #5 (permalink)
Member Number: 39594
ok pit viper what is this your 4th/5th turbo this year lol. Seriously though out of the ones you have tried which one do you like the most for daily driving, favorite one for dragging. I'm looking for a quick spooling turbo that can hold it's power to redline. Don't care about numbers that much anymore but i would say i would like to get 400hp and 450tq as for a goal in mind to meet sometime.I have been looking at the 44lb s3d and 50trim 48ar turbos. Anyways good job with the setup! Looks very nice
prkersrt4tom is offline   Reply With Quote
Old 05-15-2008, 12:26 AM   #6 (permalink)
Falbz's Avatar
Member Number: 22294
Trader Rating: (57)
Nice numbers aaron
To make a purchase please go to http://www.pt-performance.com/
Falbz is online now   Reply With Quote
Old 05-15-2008, 12:41 AM   #7 (permalink)
lyncoo's Avatar
Member Number: 43166
Trader Rating: (58)
Good numbers Aaron.
please do tell, because thats one thing i dont understand. 1st-3rd my wga opens at 4000rpm because of spinning i guess. on a 4th gear pull starting at 3k rpm my wga opens at 33-3400 rpm.
nice numbers pit what is your ignition advance at redline
thats fantastic
AGP S256 + B&G FLASH
Old 05-15-2008, 08:40 AM   #8 (permalink)
SRToc Member
Pit Viper's Avatar
Member Number: 339
Trader Rating: (60)
I would say the Stage 3 Delta, with the 44 lb. wheel. I just couldn't find a flaw with that turbo. Fast spool, no surging, great power. It was an awesome turbo.
My timing was set at a safe 24, which is what I use for anything under 21 psi, as I'm most likely on pump gas. Above 21 psi, I bump the timing up to 28 for my race-gas tune.
Interestingly enough, later in the day I floored it in 4th on the freeway, watching my knock gauge, with 26 psi of boost. Not a bit of knock anywhere, and this is on 100 octane. I wish I'd done a pull at that boost on the dyno.
As for the spool, I had no idea what to expect, really, as this turbo is a new setup for me. I looked through the 50-trim dyno post in the Turbo section, and my dyno looks pretty good. I had my wastegate start opening at 15 psi to avoid any boost spike, which probably slowed the spool down a little as well.
Old 05-15-2008, 08:50 AM   #9 (permalink)
909srt4's Avatar
Member Number: 17063
Beautiful power band ,it brought a tear to my eye
50 trim and cranes 14s = equal fast spool
*great street car cam*
909srt4 is offline   Reply With Quote
Old 05-15-2008, 06:24 PM   #10 (permalink)
Member Number: 28501
Trader Rating: (17)
where do .50 trim usualy spool at? thought it was right around 3500 on the average car?
-Jesse
I message with a lissp, sorry. <- but im not gay.
millertime is offline   Reply With Quote
Old 05-15-2008, 08:29 PM   #11 (permalink)
Member Number: 58967
damn. change turbo's like you change your undies. how do you like the fitty?
clutch slippin a lil??
Burton_Chick is offline   Reply With Quote
Old 05-15-2008, 11:43 PM   #12 (permalink)
SRToc Member
Pit Viper's Avatar
Member Number: 339
Trader Rating: (60)
no clutch at all. That ACT Xtreme clutch setup kicks ass.
Old 05-18-2008, 12:56 PM   #13 (permalink)
str5010's Avatar
Member Number: 34460
What tune number are you currently running. I might have Kevin send me this one to try out. I was running 24 degrees timing advance and was getting quite a bit of knock with meth injection or c16 in the tank when I was on the dyno.
Almost in the 11s on the 225/45/17 DRs
str5010 is online now   Reply With Quote
Old 05-18-2008, 01:28 PM   #14 (permalink)
SRToc Member
Pit Viper's Avatar
Member Number: 339
Trader Rating: (60)
24 degrees of timing here, on a 50/50 of water/meth, and 100 octane pump.
Old 05-20-2008, 04:51 PM   #15 (permalink)
NoisufnoC's Avatar
Member Number: 136
i need to work my clutch bugs out then its back to tweeking my tune w/ kevin
GTFO with your Stage 0 Nonsense!!
omgz!! i haz mods!!
