50 trim .48 A/R with 682 S2 injectors ??
(AGP) After reading the "Turbo selection guide" I have made up my mind and I've decided to go with the 50 trim .48 A/R. I already have great supporting mods for High HP, but for now I only want to make around 350 hp. I want to know if I can buy the 50 trim,SAFC2,tack driver,Big FMIC, and then pick up set of S2 injectors and run 14-16 psi on a S0 pcm will this setup work well for now until I can afford the fuel pump and 750 injectors?
For right now I want to make more power "300-350" then stop there for now and spend time on some other things, like tires and suspention.
I only want to run pump gas so the 50 trim should be just right.
If you think I should go with a .63 instead of .48 let me know. I mostly road race and street drag.
Mods
JmbPerfromance 3" CAI/Catch Can
LFS 60mm TB w/Adapter
AGP UHP w/SSQ Bov
ED LPP
Extrude Honed Intake Manifold
Unorthodox UDR Pully
Mpx 3" Exhaust w/Cat
Boomba Mounts/Motor/Tranny/Bolts
NGK LZTR6AIX-13 .040
MSD Wires
Grounding Kit
Coil Heat Sheild
DC Front Tower Bar
TWM STS w/Booger's
Drilled/Sloted Rotors
CF Clear Tails
BLK Eye Lids
Passport 8500 X50 Blue "Best Mod  "
"Go'n 50 Trim .48 A/R"
