Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendor Forums > AGP Turbo
Old 12-31-2008, 10:51 PM   #1 (permalink)
Member Number: 61737
Default 3147 question
I was curious to see what u guys thought the max whp range would be for this turbo, with supporting mods, basically what i got fuel,sct tunes,exhaust,intake,cams,intercooler. Also using straight 100oct or better
AGP 3147,3"tbe,Brian Crower S2 cams,SCT prp,KN drop in,650 injectors,255lb. fuel pump,underdrive pulley,mm inserts,eibach pro kit,
agmastakilla is offline   Reply With Quote
Old 12-31-2008, 10:55 PM   #2 (permalink)
SRT of the Month
bitts's Avatar
Member Number: 29842
Trader Rating: (94)
See sig
bitts is offline   Reply With Quote
Old 12-31-2008, 10:58 PM   #3 (permalink)
whats list of mods and how much boost?? stock engine?? (internals) what oct fuel??
Old 01-01-2009, 07:32 PM   #4 (permalink)
aww sheet's Avatar
Member Number: 20431
Trader Rating: (31)
he has s2 injectors, r/l 62 psi, 2.0 cams, and afc.
there's more but i think those are the key ones
View Modifications
Old 01-02-2009, 11:11 AM   #5 (permalink)
Jon@AGP's Avatar
Member Number: 26404
Trader Rating: (90)
The 3147 is capable of making about 440 when maxed out
Jon@AGP is offline   Reply With Quote
Old 01-02-2009, 04:36 PM   #6 (permalink)
SRT of the Month
bitts's Avatar
Trader Rating: (94)
Is that with the .63 or 48ar ?
Old 01-02-2009, 04:41 PM   #7 (permalink)
SRT of the Month
bitts's Avatar
Trader Rating: (94)
~24lbs A/F 10.3/11.2
AGP3147 .48AR
93oct/C12
S2/S3 Inj.
3bar MAP/TIP sensors
Accufab reg/returnline
Walbro 255
PTP re-wire
SAFC2
400cc water/meth inj (20/80)
2.0 cams/Findanza Gears
P/P IM
P/P TB
QW FMIC
ATP UPP/ HKS BOV
Magnaflo 3in exhaust
AEM WB/Scan gauge
S0 pcm
DIY CC
Granatelli Wires/Champion plugs/Stock coil
Turbo X/S HPBC
180* stat
On a 95* summer day also~ and KR was at O*
Ive have changed a few things since the last dyno.
Next time itll be tuned with SCT and 28lbs, ohh and those numbers are on a stock bottom end. Just checked compression 2 weeks ago 150-155 all the way across
Old 01-02-2009, 06:12 PM   #8 (permalink)
aww sheet's Avatar
Trader Rating: (31)
^^^what do you think you'd do on pump, and w/i?
Old 01-02-2009, 08:08 PM   #9 (permalink)
SRT of the Month
bitts's Avatar
Trader Rating: (94)
On 28lbs, with SCT ?
Id guess 410ish or so, Its a diffrent beast on race gas.
Old 01-03-2009, 01:40 AM   #10 (permalink)
mad1's Avatar
Member Number: 26914
Trader Rating: (10)
It's not always about hp. The correct power between holding hp and tq across the band and to be able to hook it will get you there. I run alot lower timing for my street tune. No water injection here. Maybe someday.
But it'll run on premium and drives better than new. Power comes on and pulls hard till at least 6500 rpm's. Aem 2 step helps you bang it off the line on slicks also. Got a WOT box now. Gonna put mopar short throw back in. The maddog doesn't always like WOT shifting. But it's a pleasure on the street.
Got a 50 trim here but not sure I'd like the power band. And I want the bottom end built first anyway. They come on all at once and hard. Pistons, rings, rods, and crank strap are my next projects when this economy and stuff equals out.
But I love the 3147 now. Maybe go for a race gas tune. Just load it with laptop back and forth between tunes. Damn summer needs to get here.
Last year's buy was non-modular clutch with steel flywheel. SBC Stage 5x. Great feel and grabs hard. Time below was with shitty DCR clutch. The first one. Lasted 1 track day. Pulled my DCR 2 replacement after they dropped lifetime warranty for no reason. If I can't trust it .. it's gone.
I'm 45 yrs old. Here is a big pic of my beast. It keeps me young.
3147, AEM EMS, 750's, DCR oil kt, Oil mod, DCR TB, SBC 5x , MD 72%, MAXF 3" See /res, AGP w/HKS, LC-1 WB, Raptor Shft Lt, Agp RTL w/pump. SBeast ic , AGP solids , Injen SRI. 30lb gg , billet sel, F&F P&P intake,WOT box. Stage 1 springs. 20% tint. KTP Sport alloys. Aaron tuned. Rick built.
388 hp and 420 tq @ 24 lbs w/ 94 w/6700 redline
11.95 @ 119.7.. 1.88 60'= pump gas & slicks SOLD
mad1 is offline   Reply With Quote
Old 01-03-2009, 02:26 AM   #11 (permalink)
SRT of the Month
bitts's Avatar
Trader Rating: (94)
My Tq was waaaaaaaaaaay high compared to my Hp, its nothing the DR's cant handle for the most part
I switched back to the stock shifter and WOT/2-Step help alot, havent used 2-step to much at the track though
Old 01-03-2009, 02:40 AM   #12 (permalink)
mad1's Avatar
Trader Rating: (10)
Traded my stock shifter for the maddog....core charge. So we'll see how mopar one does. Too fast or little gate for WOT shifting at times. You seem to get hung up at times with one that has too short of throw. It's even set real low. We'll see.
Slicks all the way. Then you can launch it at 4700 or so on 2 step....
Old 01-03-2009, 02:53 AM   #13 (permalink)
SRT of the Month
bitts's Avatar
Trader Rating: (94)
Fastest time at the track ?
Old 01-03-2009, 05:52 PM   #14 (permalink)
mad1's Avatar
Trader Rating: (10)
best in sig.......11.95 at 119.7mph on Dcr clutch banging off rev limiter twice ( he drove a bunch cars that day...some with 8,000 rpm limits ). I think they said other run was a 12.05 but he missed 4th. Driven by Rick at Realtune after Aaron tuned AEM. They had to replace clutch right after that with the DCR 2. I had to work that day...vacation was used up. I've just been playing with it on the street. Was a damn busy summer with fiance sick and stuff.
Now a WOT box and gonna put in new bov...Synapse Engineering Synchronic Blow Off Valve. See how it works. Supposed to kill any surging.
Got new M/T slicks right here beside me in my man room ( on PT Cruiser rims). Tire Rack carriers and a polished 50 trim on top.
Should hit 11.8's or better on a great run on pump. That'd be tits !! On Race with more boost ??? These little turbos run when you hook it.
Old 01-04-2009, 04:09 PM   #15 (permalink)
SRT of the Month
bitts's Avatar
Trader Rating: (94)
Sounds like fun man, iam thinking of upgrading to the S256, hmmm
Page generated in 0.19553 seconds with 13 queries
