Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors Forums > AGP Turbo
Old 10-03-2006, 01:50 AM   #1 (permalink)
Member Number: 39594
Default 3147 & gt3071r difference
Now i've been searching and reading on turbo's and kits and finally narrowed it down to an agp turbo kit but stuck on picking either the 3147 or gt3071r. I've been a honda owner previously and this is my first turbo car and honestly can't stand the stock turbo how it just dies from 4500-6000 but love the spool. This is my only car so i want awesome spool up characteristics but still able to make decent times at the drag strip. I'm also in colorado which the elevation creates more lag and lower power. Now i know the gt3071r is a 44 lb/min turbo but the 3147 i've read is a 47 lb/min correct? What would be the spool difference between these two turbo's. i see on your website that you say 2800-2900 on the gt3071r and 3000-3100 on the 3147 but could you really feel a difference between the two like between shifts? Do they both stay spooled if i speed shift without going open throttle shifts or do they fall out? Sorry if this is so long just i can't make up my mind.Agp please help me because right now i'm not seeing why spend 800 dollars more on the gt3071r if the 3147 can make a little more power but sacrifice 200 rpm's of spool. Lastly what are your thoughts on just oil cooled turbo's like the 3147 on life of the turbo compared to oil and water cooled. Thanks for any help Tommy
prkersrt4tom is offline   Reply With Quote
Old 10-03-2006, 09:04 AM   #2 (permalink)
Nick@AGP's Avatar
Member Number: 11546
Reliability is the same between oil and oil and water. Both spool very fast and won't fall out of boost between shifts as long as you can shift decently. I think the 3147 or 50 trim are the two best turbos for the srt4. If you are going for straight line speed or drag racing, then look into a 50 trim or DBB50.
Nick -
Do Not PM me. Email sales@agpturbo.com or call.
http://www.agpturbo.com
Nick@AGP is offline   Reply With Quote
Old 10-03-2006, 11:40 AM   #3 (permalink)
I'm looking more into a street/strip turbo but honestly i would make it to the drag strip maybe 2-5 times a year so it's basically going to be my daily driver turbo and to me i want a car that can spool great but still make decent amount of power. why i really went away from stage 3 because you have to put a piggy back on it which defeats the purpose of stage 3 because of the plug and play and i don't plan on running 100 octane everywhere i go to run in hom. Thanks Nick though i'll probably be picking up the 3147 off of you guys pretty soon. Tommy
Old 10-03-2006, 02:39 PM   #4 (permalink)
-ND4SPD-'s Avatar
Member Number: 458
Trader Rating: (30)
Tom, you're definately in the right ballpark with the 3147 & 3071R as we need that extra spool at our altitude. I think you'll be happy with either choice as price is the bigger factor the difference in performance will be.
I'd recommend (along with others here in colorado who've owned a 50 trim) to stay away from the 50 unless you're a "Track Rat" (which you've stated you're not). Daily driving isn't bad with the 50 at all but you're really like having more power down low.
The 50 trim excells at the back half of the track
The 3147/ 3071R excell in the front half of the track.
How may races or spirited street driving lasts a whole 1/4 mile? Almost none?
John Ruckman
- Stage 3 W/ Toys
- AGP WGA, Race FMIC & 3" Intake
- Custom Magnaflow Exhaust & O2
- Eibach Prokit
- B-Woody Traction Bars
- ND Performance Traction Control System
See My Ride Here
Old 10-03-2006, 03:37 PM   #5 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (30)
to tell you the truth i would go with the 3071r because it will have more low end tq like stock turbo and stag3. i have the 3147 but wouldn't mind the 3071r.
reed32 is offline   Reply With Quote
Old 10-04-2006, 01:28 AM   #6 (permalink)
it's really hard to decide because agp is the ones that know the specs of the 3147 and i don't think they want to share the inducer exducer sizes. reed have you ever been in a 3071r car? i noticed it's pretty easy to get 350 to the wheels on both setups but i've seen some good numbers on the 3147 over the 3071r. The graphs to both turbo's look identical but the 3147 seems to spool just a tad later and make a lil more top end not much though. i love how the graph is very linear almost like a roots supercharger and keeps going up not dropping off not like the 50 where at 3500-3700 a sudden boost in power. Honestly i don't know why people don't start out with these turbos first rather then 50 trim or 3076. Our powerband really likes these turbo's with our 6250 limiter.
Old 10-04-2006, 05:31 AM   #7 (permalink)
Member Number: 4829
I'm still grinning ear to ear after just making eleven passes at the track on Saturday with my 3147. I have a PT Cruiser and weigh at least 400 lbs. more than an SRT4 but that "little" turbo pulls like a freaking freight train in 3rd and 4th gear. Don't underestimate the 3147.
Added side note: Two other things that are a disadvantage to a PT Cruiser compared to a SRT4.
1. We are aerodynamicaly challenged compared to an SRT4
2. We have a final gearing ratio of 3:29 compared to 3:54 on the SRT4
Deen
03 Pt Cruiser GT, 5 spd, S1, 3147 AGP Turbo, DTEC Fuel kit, Greddy Profec B Spec II, Custom Intake Manifold w/DCR 55mm TB, DCR Oil Mod, 2-Stage W/I, Needswings 3" DP w/Dump, CCA FMIC, 180 Stat, Checkvalve, Borla Cat-Back, BTG Springs, Eibach Sways, Mopar STS w/Boogers, Panther Alloys, Eagle F1's, Best: 12.72 ET @ 115.71 MPH
Bonneville World of Speed: 139.234 MPH (speed limited by class)
katsrusdragracing is offline   Reply With Quote
Old 10-04-2006, 12:56 PM   #8 (permalink)
whiteACRsRt05's Avatar
Member Number: 38963
Trader Rating: (18)
Deen
X100 on the 3rd and 4th gear!
Quote: Originally Posted by Sweets
No ones feelings got hurt.. carlos is a brick he always bounces back even when you dont want him to..
whiteACRsRt05 is offline   Reply With Quote
Old 10-04-2006, 02:12 PM   #9 (permalink)
barrr's Avatar
Member Number: 10243
If you’re worried about spool, why don't you go the same route as Vector.
Get a GT2871R.
This came today GT2871R will be going on saturday
It has the same compressor as the GT3071R but a smaller turbine for quicker spool.
Right now I have a GT3071R & love it, but if I were to do it again, I would get the 2871.
The 3071 hits like a horse anywhere between 3000-6000RPM.
My car is a daily driver & I'm usually in the 2000-3000RPM range so a turbo with a little quicker spool would be ideal. (Yes I could down shift but I'm lazy)
Don't argue with an idiot; people watching may not be able to tell the difference.
barrr is offline   Reply With Quote
Old 10-04-2006, 02:17 PM   #10 (permalink)
mkeist's Avatar
Member Number: 8844
How do these compare to a GT3076R? I'm thinking of ordering one of these in the next week.
WHO BROUGHT ALL THE NINJA'S?
mkeist is offline   Reply With Quote
Old 10-04-2006, 02:28 PM   #11 (permalink)
Nick@AGP's Avatar
3076r is bigger, and more 50 trim size.
Old 10-05-2006, 02:26 AM   #12 (permalink)
i've kept up with vector's write up but he never said any results except his impressions. I'm trying to hit 375-400 on pump with awesome spool but also say 430-440 on race gas. When i cruise i'm usually around 2500-2800 hate going any lower because of the hills around me. The 2871r has a tiny tiny turbine t25 flange and i would have to get a custom manifold/kit. Other thing that bug me is on the 2871r and 3071r the 4" inlet and having to use a reducer to a 3". Right now the 3147 looks good and a cheaper price
Old 10-05-2006, 12:07 PM   #13 (permalink)
barrr's Avatar
I have a 3" inlet on my 3071R
Old 10-10-2006, 10:17 AM   #14 (permalink)
bigsrt4dawg's Avatar
Member Number: 33647
well i want a 500hp demon but i also have it as a daily driver. can any of these turbos reach that mark or do i need to go with a 50?
bigsrt4dawg is offline   Reply With Quote
Old 10-10-2006, 11:51 AM   #15 (permalink)
agp do you make the 3071r with a 3" inlet? or would you recommend the 4" inlet with a 4" to 3" reducer coupler for your 3" intake?
» Sponsor Links
»Garage Storage and Cabinets
