Old 09-29-2009, 11:52 AM   #1 (permalink)
Turbolife06's Avatar
Member Number: 62311
Default trunk plugs
i know you can get some from the design website but i thought i read once someone said home depot plugs? or did i not get that right? im just wondering if anyone has some info on this. if i dont like them ill get the ones offline. thanks
TIME TO GO FOR SOME POWER!
Turbolife06 is offline   Reply With Quote
Old 10-02-2009, 06:04 PM   #2 (permalink)
Figs's Avatar
Member Number: 52595
Trader Rating: (70)
I hate to see your thread go unanswered.
The plugs are just body plugs/push pins (plastic). They can be found in different sizes at any auto parts store. Usually found around the fasteners/bolts/washer section. You can even get them at a hardware store.
I don't recall the diameter of the holes on the trunk once the spoiler is removed.
If you want to color match them to the color of your car, Dodge dealers sell little spray paint cans of the color of our cars. Just spray them and spray some clearcoat on them before installing them.
Push them into the holes on the trunk, to seal them good you can put a little bit of rtv underneath them before pushing them down flush with the trunk. If the plugs aren't fully tight... the trick is take a piece of hose that fits the pin part of the body plug and push it into it within (inside) the trunk. That way its tight and won't move around.
Sounds a bit complicated but its not. I know visual pictures would help but the How-To thread on this forum on the spoiler plugs is just dead.
Hope that helps
Figs is offline   Reply With Quote
Old 10-02-2009, 08:09 PM   #3 (permalink)
dcsax's Avatar
Member Number: 4232
Trader Rating: (13)
Yes, what he said ^^^ These are the same as what you would by from a vendor. The plugs you need are for the interior panels of a Dodge neon. You can see what the plug looks like if you pop your trunk (they are what hold the trunk carpet to the side of the trunk. This is a VERY easy mod.
Mods: Lots of stuff
dcsax is offline   Reply With Quote
Old 10-03-2009, 02:27 PM   #4 (permalink)
yea funny part is i was at pepboys after i wrote that question and i was like fuck it im gonna buy taps that you use to hold the carpet in and put silicone on them and try that...and then you guys post to do that very thing. i just never knew anyone meant to use THOSE. but its all good, looks great, and doesnt leak so im happy. thanks guys
Old 10-03-2009, 04:42 PM   #5 (permalink)
silverbullitsrt's Avatar
Member Number: 35803
look in the how-to section it gives u p/n # for the trunk plugs at home depot and and find out what paint u need from your local dealership and paint them takes about 1/2 day to do it enable for the paint to dry
Its still only a neon
silverbullitsrt is offline   Reply With Quote
Page generated in 0.13566 seconds with 13 queries
