Old 11-04-2009, 01:40 PM   #16 (permalink)
Member Number: 76002
Default hai
On a lathe.
CarsAddict is offline   Reply With Quote
Old 11-04-2009, 01:44 PM   #17 (permalink)
OrionR12's Avatar
Member Number: 21193
Trader Rating: (146)
Darksyde! PM him and he will hook you up with a SWEET shaved VC!
-ryan-
'04 eBlue SRT-4 (44lb SNL Shocker Stage 3 w/ toys)
387hp 442tq w/ clutch slipping & kicked out HOM
Award winning thanks to DARKSYDE!
In memory of Steven Nightshade Lorenz
OrionR12 is online now   Reply With Quote
Old 11-04-2009, 10:43 PM   #18 (permalink)
Member Number: 33203
Trader Rating: (25)
I do all mine with a small angle grinder.
Precision 6057@30psi on pump
Contact Turbo666/TDSaaron for your tuning needs.
turbojonsrt4 is online now   Reply With Quote
Old 11-07-2009, 01:30 PM   #19 (permalink)
SRT of the Month
bitts's Avatar
Member Number: 29842
Trader Rating: (98)
I got me an extra VC, im gna take it to work and set it up on my mill, see how quick I can get them letters off
Ill get some pics to.
bitts is offline   Reply With Quote
Old 11-07-2009, 06:06 PM   #20 (permalink)
Member Number: 39007
Quote: Originally Posted by COY View Post
a mexican.
Came back the next day smooth and polished.
haha too funny.
Also have thought about this, what other 2.4 liter valve covers are out there? like the stratus? What does it look like?
Im going to shave mine, weld up the coil pack holes, move the coil pack (somewhere) use different spark plug wires (obviously) and finish my 2 port breather set up with a LS1 vac pump.
JMB
Red 04, t04z, meth, spray, crane 18's
639hp/649 tq
RarB!tch is offline   Reply With Quote
Old 11-07-2009, 10:07 PM   #21 (permalink)
SRT of the Month
bitts's Avatar
Trader Rating: (98)
Relocating the coil pack it a good idea, longer harness, plug wires.
Some guy already did that Ghost-1 or some shit like that.
Old 11-08-2009, 12:46 AM   #22 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (19)
if you dont have access to a million dollar shop you can use a small router with a 1/4 carbide bit, , make sure the router height is locked in good. it will take it off in no time, then you would need to sand the entire cover once your done
Old 11-08-2009, 02:37 PM   #23 (permalink)
Member Number: 36585
please explain..cause of the heat?
just-a-neon is offline   Reply With Quote
Old 11-08-2009, 03:45 PM   #24 (permalink)
nutz's Avatar
Trader Rating: (19)
danmm thats sweet, now I wanna do mine, is that WC spray paint or some other type of coating. I could never get the WC spray paint to work right (freeking flat streeks)
Old 11-08-2009, 05:37 PM   #25 (permalink)
SRT of the Month
bitts's Avatar
Trader Rating: (98)
Carbide bit ?! Carbide willl typically 'pull and grab' aluminum, a tool steel bit would leak a better finish but whatev
Mostly for looks.
Page generated in 0.14727 seconds with 13 queries
