Old 04-27-2007, 05:14 PM   #1 (permalink)
Member Number: 29488
Default Removing Wing....?
what size wrench do I need to take out the 4 screws to take out the wing? any tips...? THANK YOU!!
94Dawg is offline   Reply With Quote
Old 04-27-2007, 05:24 PM   #2 (permalink)
White Heat's Avatar
Member Number: 512
Trader Rating: (10)
I can't remember if they are 8mm or 10mm. It's been a while. After removing the nuts the wing probably still won't come off. I had to hit the underneath of the wing up to get it off. Just do it carefully. The paint may be chipped around the holes and if you are using plugs hopefully they'll cover.
'05 Stone White SRT 4
Mods - Yes
Web Page
http://qt.ptenthusiasts.net/
White Heat is offline   Reply With Quote
Old 04-27-2007, 06:02 PM   #3 (permalink)
$RT4's Avatar
Member Number: 25543
I use needle nose pliers then I used some of that spongy foam stuff they use as padding on leg curl extensions from my old weight bench,cut into squares and forced into the sockets-works perfect on mine!
$RT4 is offline   Reply With Quote
Old 04-27-2007, 11:44 PM   #4 (permalink)
SRTchild's Avatar
Member Number: 32169
they are 10mm nuts. just took mine off today.
Aem CAI, Agp WGA, Stage 1, Ndswngs V6, MPx BFIMC, Aeroforce Scangauge, AEM EUGO, MPx Dual Gauge Pods, Yellow Foglight Bulbs, Laminx, Bdjs Shorty Antenna, Eibach Pro Kit, Prothane Endlinks, ESMM, 20% Tint, PTP Coil HS, Taylor Wires, NGK 4306s, $20 Catch Can, Mopar Front Badge, SRT-4 V2 Badge, PTP Check Valve, ED Blitzz TT, TurboSmart MBC, Rota Slipstreams, Bridgestone Potenza RE-01 R's
SRTchild is offline   Reply With Quote
