its really simple pull out the tabs in the trunk carpet and pull it back and remove the 3 bolts i believe they are 10mm and for the brake light theres two 10mm nuts you take off and remove the bulb by turning it and BAM your lights are removed... and when tinting them make sure you do some light wet sanding in between coats light coats is the key to eveness
