Old 06-08-2008, 05:52 PM   #1 (permalink)
foxracing12002's Avatar
Member Number: 45389
Trader Rating: (20)
Default how do you remove the door panel?
need to get my front driver and passenger side door panel off and im stumped. i only see 2 screws and i need to know asap. any help is appreciated. thanks
Danny
Ruthless.
TRACTION PWNS ME!!
ANTI-SWEETS CLUB MEMBER # 2
foxracing12002 is offline   Reply With Quote
Old 06-08-2008, 07:26 PM   #2 (permalink)
SRToc Member
arn4726's Avatar
Member Number: 22852
Trader Rating: (17)
since u have the s first name as myself i guess i can lend a helping hand.. there are 3 screws in total holding the door on... one above the speaker area at the top with its own hole... and two in the door handle area.. one is hidden behind a little plastic peice and the other one is straight down in the door handle... then get a flat head screw driver wrap in a towel or t shirt and pry between the pastic and the door on the bottom... the door is attatched buy a bunch of plasic christmas tree fasteners... they just pop out... then lift it out... the window and door lock area has wire harnesses that you will need to detatch so be carful not to let the door hang too much since it will be holding only by the wires... how this helps
arn4726 is offline   Reply With Quote
Old 06-08-2008, 08:18 PM   #3 (permalink)
Trader Rating: (20)
hey thanks man, i was actually gonna delete this thread cause i found out. you have to ape on that shit to pop it off. and i disconnected all the wires first
but thanks for the response!!
Page generated in 0.16744 seconds with 11 queries
