Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > International Forums > Overseas/Foreign
Old 05-28-2008, 03:33 AM   #1 (permalink)
texwill's Avatar
Member Number: 54508
Default running hot?
I was wondering what the normal operating temp was on the SRT-4? I was running my car yesterday with the AC and the temp went above the 200 mark about 210-215! Should I buy a different thermostat? It seems that is too hot, where can I buy one? I checked modern but they only sell OEM thermostats, thanks!
texwill is offline   Reply With Quote
Old 05-28-2008, 03:42 AM   #2 (permalink)
jxmann's Avatar
Member Number: 57530
i have a 180* thermostat and i usually sit right at 200
jxmann is offline   Reply With Quote
Old 05-28-2008, 11:23 AM   #3 (permalink)
Overseas Moderator
Member Number: 33071
Trader Rating: (76)
Mine rises a little above 200 before it comes back down.
marakka is offline   Reply With Quote
Old 05-28-2008, 11:27 PM   #4 (permalink)
schnuppi_2's Avatar
Member Number: 33172
Trader Rating: (41)
180 tstat and fan mod, i never go above 180
schnuppi_2 is offline   Reply With Quote
Old 05-29-2008, 11:28 AM   #5 (permalink)
shiby3041's Avatar
Member Number: 43864
I believe the normal op temp is between 190 and 210 however 215 isn’t so bad given conditions. you said AC was on, im assuming a hot day. And you probably hit it when you were still or rolling slow. Plus if your car is the black one on the pic a black hood radiates the heat bad. SO i would think your cool with that temp. nothing to worry about if you go much higher maybe raise an eye brow.
shiby3041 is offline   Reply With Quote
Old 05-29-2008, 11:35 AM   #6 (permalink)
MonsterLemon's Avatar
Member Number: 48761
Trader Rating: (42)
yeah mine hits 210-215 on hot days. check your coolant level and is it boiling the overflow when you shut the car off at full temp? If so replace your radiator cap.
MonsterLemon is offline   Reply With Quote
Old 06-01-2008, 05:48 AM   #7 (permalink)
pinball-koenig's Avatar
Member Number: 3026
Welcome to SRT world....normal! To cool things down (not just in the car) turn on your AC. It's linked to your radiator cooling fans. When I'm stuck in traffic, I'll turn the AC to help bring temps down.
Bob
pinball-koenig is offline   Reply With Quote
Old 06-01-2008, 06:44 AM   #8 (permalink)
Legoman's Avatar
Member Number: 53967
Are you sure? I know it the completely opposite way. Open the windows, turn the fan on full power and full heating. That will bring the heat away from the motor through your car and out the windows. you will sweat, but not the car...
as known as Jenni on 2gn...
Quote: Originally Posted by marakka
Viel dank Carsten. Ich liebe dich. Du bist mein TOPMODEL!!!!
Legoman is offline   Reply With Quote
Old 06-01-2008, 10:25 AM   #9 (permalink)
schnuppi_2's Avatar
Trader Rating: (41)
180 tsat is the way to go. Then look up in the How to for the Fan Mod. Only a switch and wire going to fan soleniod. I just have mine on all the time. Is cool for the track cause you can have car off with key to on position and the fan just runs. I never go above 180 except for at the end of a run at the strip, but by the time i make it back around to staging lanes it is back to 180.
Old 06-01-2008, 02:16 PM   #10 (permalink)
Overseas Moderator
Trader Rating: (76)
Doing that mod is asking for trouble unless its just adding an option to turn the fan on when you want AND having the sending unit control the fan. I can already see someone forgetting to turn their fan on and hitting a stau.... next thing you know they'll need a new head.
Old 06-02-2008, 12:35 AM   #11 (permalink)
schnuppi_2's Avatar
Trader Rating: (41)
If you dont have the switch on the soleniod will still turn it on. just gives you the option to turn it on when it wouldnt normally be on. But i just always have mine on
Old 06-03-2008, 08:56 AM   #12 (permalink)
texwill's Avatar
Thanks everyone, I am going to the how to section now!
Old 06-05-2008, 05:25 AM   #13 (permalink)
Member Number: 3026
Legoman
You're speaking old school...the car industry got smart a few years ago and linked the a/c demand with the cooling fans on most cars. Turn your car on when the engine's stone cold, then turn your A/C on....you'll notice the fans both jump into action.
Old 06-06-2008, 07:59 AM   #14 (permalink)
Legoman's Avatar
Maybe. But with AC the engine must work more - and will running hot more.
Page generated in 0.17703 seconds with 11 queries
