Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > International Forums > Overseas/Foreign
Old 08-04-2009, 05:14 AM   #1 (permalink)
Lupis's Avatar
Member Number: 47638
Default Need help asap
Well i just got my neon over here yesterday. It ran fine until this morning when i started it to go to work. the car didnt want to stay running and would run like complete ass when i actually got it going. My wide band will completely lean out the car will jerk and shudder. I started throwing a P0107 so i thought it could be the wiring for my AFC Neo but i double checked all the wires and everythin seems to be hooked up right and all the wires are soldered together with electrical tape wrapped around it. I also check for the wiring leading to the Map sensor but all of those seem to be good. Now my question is it seems like ( to me at least) that i need a new map sensor. Can i use a stock map sensor since i am controlling the fuel anyways or does it have to be a 3 bar. Also...does someone have one. I am in the Hohenfels GE area.
Mod list:
Performance:
PTP SSTv2 (Ported Stock Turbo)
PTP Intimidator Exhaust Manifold
PTP Cold Air Intake
Mopar stage 2 computer
3 Bar Map and Tip Sensors
Deatchworks 650cc injectors
PTP Wastegate
PTP 55mm Throttle Body
Evil Creations Big Front Mount Intercooler
Custome 3" TurboBack Side exit Exhaust
3" o2 Housing
PTP Fuel Pump Rewire
PTP Cold Side Pipe W/ TurboSmart Blow off Valve
Upgaded Plug Wires
Mopar Short Throw Shifter
Electronics And Guages:
AutoMeter 30/30 Boost Guage
Apexi Neo Air Fuel Controller
NGK wideband
Blitz Turbo Timer
I need to get the car running asap so my wife has something to drive when i leave thurday...thanks
Chris
Running out of bolt ons...
Lupis is offline   Reply With Quote
Old 08-04-2009, 04:22 PM   #2 (permalink)
Legoman's Avatar
Member Number: 53967
Please check every wire - especially the spark plug wiring - if maybe the martens came at night and tried to eat your engine!
Legoman is online now   Reply With Quote
Old 08-05-2009, 01:13 AM   #3 (permalink)
Lupis's Avatar
Update....its working again...wierd the AFC was zeroed out so i had to retune it but its back to its old self again..
Page generated in 0.13242 seconds with 13 queries
