Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Racing Discussion > Autocross/Road Racing
Old 04-18-2008, 03:40 PM   #1 (permalink)
Member Number: 45460
Default weight reduction question
ok i read the weight reduction sticky but was wondering if anyone actually cut the spare tire space out and screwed or welded a piece of sheet metal to cover the hole...would that affect anything with the body maybe twisting or anything of that nature..
thanks
luvinboost is offline   Reply With Quote
Old 04-18-2008, 05:57 PM   #2 (permalink)
[vu]juan's Avatar
Member Number: 33153
Trader Rating: (34)
I don't think it would be cost effective or yield any significant benefits, certainly not worth it in my opinion.
"It's better to burn out than fade away." - Kurt Cobain
[vu]juan is offline   Reply With Quote
Old 04-18-2008, 08:29 PM   #3 (permalink)
GLH
GLH's Avatar
Member Number: 13115
Trader Rating: (35)
we did but we changed the whole rear end you wont save much as you have to keep the rear suspension cross member and thats where the weight is
86 GLHS 315
05 SRT4 GT-A #166
2008 Mobile 1 GT Sprints
2007 Canadian Touring car Championship
sponsored by Fast Trac /ftrac.org
GLH is offline   Reply With Quote
Old 04-18-2008, 08:31 PM   #4 (permalink)
HCCAFan's Avatar
Member Number: 35768
Trader Rating: (18)
Madness!
HCCAFan is offline   Reply With Quote
Old 04-19-2008, 01:19 PM   #5 (permalink)
ok i wont mess with it then figured if i save a good 50 or 80 lbs i would cut it out..thanks though..do you know were i can get lexan or do you use that home depot sutff...
Old 04-19-2008, 01:52 PM   #6 (permalink)
GLH
GLH's Avatar
Trader Rating: (35)
we took almost 100 lbs by going to a carbon fiber rear deck removing all the hardware and cutting out the particial shelve and lexan rear window
Old 04-21-2008, 03:28 PM   #7 (permalink)
were did you get your lexan from...
Old 04-21-2008, 07:43 PM   #8 (permalink)
GLH
GLH's Avatar
Trader Rating: (35)
a local glass guy its really not hard to find
Old 04-22-2008, 07:58 AM   #9 (permalink)
1LAPSRT's Avatar
Member Number: 38267
Trader Rating: (19)
Of course taking all the weight out of the back makes the cars balance that much more sckewed.
GLH, what is your % balance?
Heading for a new track? Just want to improve your times at a track you already run?
1LAPSRT is online now   Reply With Quote
Old 04-22-2008, 12:38 PM   #10 (permalink)
GLH
GLH's Avatar
Trader Rating: (35)
we are about 2 weeks away from having it all together our first track day is may 9th Ill let you know but we took over a 100 lbs from the from as well we should be under our 2700 lb limit so we can add to get the correct balance
Old 04-26-2008, 07:30 PM   #11 (permalink)
Member Number: 26920
I was just thinking about the same thing...
I will also remove that section and will replace with some superlight material:P
I don't want to kill the surprise, but once we are ready with my new setup...well it will be something new for sure
Speed doesn't kill, the sudden stop does!
Numbers: 659.1whp 620.4wtq (detuned )
Here is the link to my mods:
http://www.srt4monster.com/mods.htm
JohnyNFS is offline   Reply With Quote
» Search Used Cars
Page generated in 0.34789 seconds with 11 queries
