Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Racing Discussion > Autocross/Road Racing
Old 08-16-2006, 10:14 PM   #61 (permalink)
Back-n-Black's Avatar
Member Number: 15950
Trader Rating: (42)
Just reading threw all the great info here and wanted to mention that S&P stocks both the air conditioning pullys for removing the AC and air bag removal kits for the passanger bag, complete with resistor to keep the dash lights off. Happy to help people reach there wieght loss goals.
www.speedandpowerdevelopment.com
Randy
S&P Tech Rep
Mopar & Dodge parts!!email:randy.speedandpower@gmail.com
Build it!!! Photo=Suzq044
Wood Frog's where the NW gets fast!!
Back-n-Black is offline   Reply With Quote
Old 08-17-2006, 06:46 AM   #62 (permalink)
SRToc Member
Bacardi 151's Avatar
Member Number: 14061
Trader Rating: (34)
Randy
Great info!
Once you tackle all the free things, removing the ac is probably the best bang for the buck in terms of dollar/weight ratio...You lose a major ammenity...The battery is also a pretty good bang for the buck and one won't notice a difference...
Former 295hp/344tq owner
Bacardi 151 is offline   Reply With Quote
Old 08-18-2006, 12:38 PM   #63 (permalink)
Member Number: 35407
Do you have a direct link, or a Part # and price on the AC bit. I took one of the hoses out in a little incident with a not so little concrete barrier. Might as well pull the whole system.
thetable is offline   Reply With Quote
Old 08-18-2006, 01:20 PM   #64 (permalink)
Trader Rating: (42)
We have not got it added to the web site yet but here is a link that tells how much and our paypal.
AC Delete made easy! (S&P AC Delete KIT)
Thanks for checking it out.
Randy
Old 08-22-2006, 05:56 AM   #65 (permalink)
Member Number: 12036
Trader Rating: (17)
didn't see anything for sway bars. you can lose a lot of weight from stock to say hotchkis
Mods: Got too many to actually remember
srtjay is offline   Reply With Quote
Old 08-22-2006, 06:04 AM   #66 (permalink)
SRToc Member
Trader Rating: (34)
The rear hotchkis sway weighs more than the stocker...The front weighs less...
Old 08-22-2006, 02:18 PM   #67 (permalink)
noTe's Avatar
Member Number: 43
Trader Rating: (28)
Are you sure about that? I thought both the hotckhis are lighter.
noTe is offline   Reply With Quote
Old 08-22-2006, 03:03 PM   #68 (permalink)
SRToc Member
Trader Rating: (34)
http://home.comcast.net/~omniphil/acr4/
Stock rear sway 8.02lbs...
Hotckhis rear sway 9.4lbs...
Old 08-22-2006, 03:11 PM   #69 (permalink)
noTe's Avatar
Member Number: 43
Trader Rating: (28)
Ah.. I think what I heard was the Hotchkis rear sway bar is lighter than all of the other aftermarket sways.
Old 08-22-2006, 03:16 PM   #70 (permalink)
SRToc Member
Trader Rating: (34)
Sounds right...OmniPhil just needs to get his hands on all other sway models so he can weigh them on his calibrated scale...
Old 08-22-2006, 07:47 PM   #71 (permalink)
GLH
GLH's Avatar
Member Number: 13115
Trader Rating: (34)
This is corect but the Hotchkis rear is lighter than as of the other big rear bars so it's still the best upgrade for suspension but yes you take a little hit compared to the stock bar
86 GLHS 315
05 SRT4 GT-A #166
2008 Mobile 1 GT Sprints
2007 Canadian Touring car Championship
sponsored by Fast Trac /ftrac.org
GLH is offline   Reply With Quote
Old 08-23-2006, 06:13 AM   #72 (permalink)
SRToc Member
Trader Rating: (34)
I agree with you that it is the BEST upgrade...
If you want save some money, the best bang for the buck would be the ACR rear sway and poly bushings...
Old 08-23-2006, 08:37 AM   #73 (permalink)
Trader Rating: (42)
I was thinking the same thing. That the ACR 19mm bar can't weight much more than our stock bar and i bet it is lighter than the Hotch. When you realy think about it the sway bars set lower on the car than most anything so added wieght there is not going to effect the car much if at any. It is the weight up higher, like the a/c condinsor and air bags that kill a cars handling. Not to mention sun roofs. The sway bar is also considered mostly unsprung weight since it connects to the LCA and that is all unsprung weight so saving a few pounds there will not change anything.
Randy
Old 08-24-2006, 01:28 PM   #74 (permalink)
Super Moderator
stowaway's Avatar
Member Number: 3286
Randy
actually, both of the cheapy sways are noticeably heavier than their stock counterparts. At least when i was carrying them around and under the car I could tell which was which.
Old 08-24-2006, 03:38 PM   #75 (permalink)
rallyfreak's Avatar
Member Number: 3825
Randy
I have to disagree here. The stabilizer bar is mostly sprung mass. Any mass between the cushions is sprung mass. A large portion of the material outside of the cushions is also sprung. Stabar links and fasteners are totally unsprung.
That wasn't my main issue though. Saving unsprung mass is HUGE!!! Less unsprung mass allows the dampers to more finely control that mass. In other words, less mass equals better wheel control equals better tire interface to the ground more of the time which results in more grip. Don't beleive me? Put a set of heavy wheels and tires on your car. Drive it around for a few hundred miles, or spend a week driving it back and forth to work. Then put some lightweight wheels and tires on. The ride quality will improve significantly, because the dampers have an easier time controling the unsprung mass.
Steve B.
2005 SRT4 ACR
3rd DS 2007 ProSolo National Championship
3rd DS 2006 ProSolo National Series
5th DS 2006 Solo National Championship
1st 2006 Washington DC ProSolo
1st 2007 Toledo ProSolo
rallyfreak is offline   Reply With Quote
