Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Racing Discussion > Autocross/Road Racing
Old 09-18-2009, 03:36 PM   #1 (permalink)
uturner's Avatar
Member Number: 13844
Default SRT-4 Wheel Rate
Does anyone know the effective wheel rate on the SRT-4s? Also, what Hz of spring should be used for a stiff AutoX car?
uturner is offline   Reply With Quote
Old 09-23-2009, 05:57 AM   #2 (permalink)
Stitch's Avatar
Member Number: 11411
Umm... Hz is a measurement of cycles, such as how many times something occurs over a period of time. Spring rates are measured as the amount of pressure, or weight, needed to compress the spring a certain distance.
Shocks dampen the movement of the spring, which in turn has an effect on the bound and rebound cycles of the spring. Usually, the stiffer spring rate you use, the stiffer dampening the shock should have.
I'm guessing you are trying to ask what spring rate to use for AutoXing...?
Tuned by Aaronneon of REALTUNE PERFORMANCE
What's a warranty?...
Stitch is offline   Reply With Quote
Old 09-23-2009, 02:51 PM   #3 (permalink)
DJFahr11's Avatar
Member Number: 25197
Trader Rating: (29)
I'm guessing he's asking pretty much what he's actually asking... he could have probably said what spring frequencies though I've read (meaning don't take it as a definitive answer) that 2.2hz front and 2.5hz rear is good to shoot for.
DJFahr11 is offline   Reply With Quote
Page generated in 0.14526 seconds with 13 queries
