Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Racing Discussion > Autocross/Road Racing
Old 06-30-2008, 04:24 PM   #16 (permalink)
rallyfreak's Avatar
Member Number: 3825
Don't fret, I doubt it will happen. The SRT-4 ACR can keep up with a GS Mini. That's why we aren't afraid of having them move down to D stock with us.
Steve B.
2005 SRT4 ACR
3rd DS 2007 ProSolo National Championship
3rd DS 2006 ProSolo National Series
5th DS 2006 Solo National Championship
1st 2006 Washington DC ProSolo
1st 2007 Toledo ProSolo
rallyfreak is offline   Reply With Quote
Old 06-30-2008, 04:26 PM   #17 (permalink)
dasmopar's Avatar
Member Number: 6413
Trader Rating: (148)
Was DS faster than GS last year at Nationals?
dasmopar is offline   Reply With Quote
Old 06-30-2008, 06:13 PM   #18 (permalink)
Elected Moderator
stowaway's Avatar
Member Number: 3286
DS was .5 faster on the combined times.
Old 06-30-2008, 07:18 PM   #19 (permalink)
Member Number: 51620
I don't have an ACR but my friend is saying that I should expect a BIG difference once I get some really good street tires for autocross. I don't know exactly what that means, but I'm sure a second faster is a good approximation because the tires I have right now are pretty crappy. lol
This is a little off topic, but a former SRT-4 owner I met at an event told me that "crash bolts" are stock legal. Is that true? I've been running stock camber (nearly zero) at every event so it would be nice to get some negative camber.
"75% Driver, 25% Tire, 5% setup." -D.G.
V-Kidd is offline   Reply With Quote
Old 06-30-2008, 11:14 PM   #20 (permalink)
Member Number: 12401
Good street tire = Falken RT615, or RE01-r, or if you have to bread, Yoko AD07's. They will make the biggest difference of any single mod to your times by a lot. Those tires are all extremely sticky.
Atlas is offline   Reply With Quote
Old 07-01-2008, 04:13 AM   #21 (permalink)
JmalB's Avatar
Member Number: 6784
And yes the camber bolts are legal. IIRC you can only use one bolt per strut. I've read some people using two bolts (top and bottom) to get more camber, but that's not legal for stock class. Going off of my notoriously bad memory...
AZ SRT-4 owners forum Loud pipes and other myths.
Quote: Originally Posted by essareteesicks View Post
Your e-penis is a mighty e-beast and feared by e-tribes everywhere.
Quote: Originally Posted by ILLJIM69
and for the record............i fail!!!!!!!!!!
jim
JmalB is offline   Reply With Quote
Old 07-01-2008, 11:53 AM   #22 (permalink)
SteveW's Avatar
Member Number: 35487
Two bolts per strut are just fine in Stock.
Steve W.
2005 ACR SRT-4
#66 DS
http://www.cardomain.com/ride/2561378
The gods live at corner entry - Randy Pobst, June 2006 Sportscar (paraphrased)
SteveW is offline   Reply With Quote
Old 07-02-2008, 01:25 AM   #23 (permalink)
JmalB's Avatar
Member Number: 6784
There you have it.
Old 07-07-2008, 01:53 PM   #24 (permalink)
BTW, what is the part# for those bolts - I'm running 0* camber in the back right now and it's pissing me off - I want to put in more camber but I don't want to get camber plates to do it...
Old 07-07-2008, 01:58 PM   #25 (permalink)
Elected Moderator
stowaway's Avatar
Member Number: 3286
wow, you have 0° camber in the rear? Every SRT-4 I've seen has had at least -1° off the factory assembly line.
Old 07-08-2008, 02:43 AM   #26 (permalink)
JmalB's Avatar
Member Number: 6784
You want 0 camber in back for autocross. Positive camber is better. You'll definitely want to check your front camber though. That's probably positive and you want it to be as negative as possible.
Old 07-08-2008, 06:03 PM   #27 (permalink)
I did some research in here and found some part numbers for the crash bolts. I don't know what vendor sells it, but I'm assuming it's Mopar?
5019 074 AA
4773 957
Old 07-08-2008, 06:15 PM   #28 (permalink)
My car came with 0* in back from the factory. I have RE01Rs, which like camber. I'm running 1.75* in the front, and I was going to run 1-1.5 in the back.
V-Kidd, thanks, I'll have a look.
Old 07-10-2008, 06:53 AM   #29 (permalink)
pdqsrt4's Avatar
Member Number: 23765
Go to your local Dodge Dealer to buy.
Here's a link from neons.org.
Go to 2003.5.2
Q: How can I adjust camber on my PL2k Neon?
Neon FAQ: PL2k Suspension
pdqsrt4 is offline   Reply With Quote
Old 07-12-2008, 05:12 PM   #30 (permalink)
Just to be safe, where in the rulebook does it say that the use of one or two crash bolts are stock legal? Because it seems like they're not after I read this:
B. Both the front and rear suspension may be adjusted through
their designed range of adjustment by use of factory adjustment
arrangements or by taking advantage of inherent manufacturing
tolerances. This encompasses both alignment and ride height
parameters, if such adjustments are provided by the stock components
and specified by the factory as normal methods of adjustment.
However, no suspension part may be modified for the
purpose of adjustment unless such modification is specifically
authorized by the factory shop manual for non-competition
purposes.
Unless the use of crash bolts is stated by the factory as a normal method of adjustment, then all crash bolts are not legal..
Page generated in 0.19712 seconds with 11 queries
