Does anyone else have overheating issues @ the track? I was out in Dunnville Ontario on Saturday and was overheating after 10-15 minutes. It was 85-90 outside. I ordered a Koyo radiator and Hondata intake manifold gasket, so hopefully those will help. Also, going to switch the coolant. Any other recommendations? This is the first time I've had a problem. No problems at Watkins Glen or the other times I've been to Dunnville, although it hasn't been that hot either...
04 Black SRT-4: Stage 2, Stage 3 coilovers and more
You might just have old fluid? I have never overheated on track and I run in the SE where it is normally in the 90-100 range. My car will typically get up to about 235-240, but hasn't made it into the red zone yet.
I would do a complete flush and make sure you take your time and purge all of the air out of your system before making any runs on the road or the track. Several cold => operating temp. cycles making sure to bleed air out via the bleeder below the radiator hose.
180 degree tstat is a good idea too the 200 that comes in the car is too warm for track. 160 is a little too low .. you cant redline the motor till it opens and the rest of the fluid warms up.
I believe those inserts increase the airspeed into the radiator.
heh perhaps .. but more so do they keep from allowing the dissipation the positive preasure. =] I think increasing their size would be better than removing them.
