Installing 5point harness without roll bars or cage...
I was thinking for when I go on road course.
To install 5 point harness what if I ran should straps straight back to rear deck top and use Reinforcement plates
run the rears to the lower rear seat belt mounts. i would trust the cars factory belt holes of a 2 tack welded mount plate.
just thought the angle might be too far down..
plates go under the sheet metal and u drill hole for bolt. The plate would have to rip thru sheet metal.
You don't want to run the shoulder straps down to the floor, that's way too great of an angle to run them. You want them within 10-15* of your shoulders if I'm not mistaken.
It wouldn't be safe to install 5-points without a roll bar or roll cage. The sub belt will not let you submarine in the event of a rollover. This means your head will get crushed from the roof of the vehicle. Also, running the shoulder belts at incorrect angles could equal spinal/neck injury. You are also risking damage to your hips, crotch, etc. from improperly mounted lap belts.
Please consider a Scroth setup that is made for vehicles without roll cages.
is there a rollbar for our car you can bolt in and out for when u goto the track and take out when your street driving and people in back seat
(though I hardly ever have people back seat
I can't believe that most people don't consider this when purchasing 5-point harnesses!
Since the OP didn't mention installing a Schroth (most people buy other brands), I wouldn't give information pertaining to that brand and ONLY that brand!
This is much more universal information and clearly states no more than a 10* angle from the shoulder to the mounting point. IE - NOT the rear floor mounts for the factory seatbelt.
as to that site rear deck doesnt work its above shoulder..
i definately know shoulders straps cant go to floor thats how u compress ur spine and cause damamge.
guess im going to have to look into roll bars..
gonna write scrotch and see what they say too
