Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Racing Discussion > Autocross/Road Racing
Old 07-17-2008, 10:46 AM   #16 (permalink)
1LAPSRT's Avatar
Member Number: 38267
Trader Rating: (19)
Quote: Originally Posted by Postal View Post
Correction on my tires - The Dunlops are 235 not 245, the 245 was on the Falkens. Should I get ACR struts vice Standard SRT struts for the Koni coil overs?
The cheaper the better!
All they (or you) do is cut off the spring perches and the ends and dump all the guts into the trash can.
Heading for a new track? Just want to improve your times at a track you already run?
Old 07-17-2008, 03:25 PM   #17 (permalink)
DrmCtchr's Avatar
Member Number: 38971
if you can get your tires and wheels to fit under the ACR struts they are nice due to the lowering of the roll center.
DrmCtchr is offline   Reply With Quote
Old 07-17-2008, 07:21 PM   #18 (permalink)
Super Moderator
stowaway's Avatar
Member Number: 3286
235/40-17 MIGHT fit below the ACR struts, but if you go to the Koni/GC setup then it doesn't matter what strut body you use (SRT or regular neon) because the perch will be cut down to fit the GC spring perch on.
Old 07-17-2008, 10:48 PM   #19 (permalink)
SteveW's Avatar
Member Number: 35487
Ahh, just get plain old Neon struts and stick Koni inserts in them if you want to go that route. Probably cheaper and will perform better than the Tokicos that came with ACRs. (edit: the reason I say this is I believe the dimensions of the ACR struts are actually the same as standard Neons as opposed to the taller SRT-4)
The 235/40/17 Star Spec is shorter than a 225/50/16 Kumho 710 so it ought to fit. The 235/45/17 Star Spec would not fit, however.
Steve W.
2005 ACR SRT-4
#66 DS
http://www.cardomain.com/ride/2561378
The gods live at corner entry - Randy Pobst, June 2006 Sportscar (paraphrased)
SteveW is offline   Reply With Quote
Old 07-18-2008, 06:59 AM   #20 (permalink)
dasmopar's Avatar
Member Number: 6413
Trader Rating: (148)
As for the tires, I know of a lot of people who ran Falken rt-615 last year (me included) and they have switched to the new Dunlop Direzza Sport Z1 Star Spec tires. Last year I could not get the Falken to generate any heat and the Dunlops get to temp real quick.
As for the suspension set up - are you sugesting Koni inserts then trash that set up and get coil overs or does Koni offer a coilover set up?
How will those dunlops hold up for daily driving? 6 to 8K miles a year. What size should I get for stock ACR wheels? (16X7) Car is on coilovers and has camber caster plates now so I have plenty of room between the wheel and the struts.
Sorry for the high jack.
dasmopar is offline   Reply With Quote
Old 07-18-2008, 07:55 AM   #21 (permalink)
Super Moderator
stowaway's Avatar
Member Number: 3286
for DD use the 225/50-16 is a safe bet. It's also the biggest 16" size available. I don't see why you couldn't get 8-12k out of a set. Hell, I got 15k on a set of RT-615s.
Page generated in 0.19926 seconds with 11 queries
