Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Racing Discussion > Autocross/Road Racing
Old 05-14-2008, 08:31 PM   #1 (permalink)
pdqsrt4's Avatar
Member Number: 23765
Question Car stumbles @ WOT after 5lbs of boost. Any ideas?
Need some help here.
If I'm driving along (lets say 55mph and in 5th gear) and have lots of vacuum and floor it, the boost will build. At about 5lbs of boost, the engine will start to buck. And when I say buck I mean it's like the car has power, then has no power, then has power, then has no power.
If I start from a stop, and accelerate through the gears, not a problem.
Any ideas, somethings not right.
pdqsrt4 is offline   Reply With Quote
Old 05-14-2008, 08:35 PM   #2 (permalink)
jstbrd's Avatar
Member Number: 10925
Plug wires? I had a similar problem and it was fixed by replacing the wires.
04 SRT4
Mopar Stage 3 Coils
Stoptech ST40s
jstbrd is online now   Reply With Quote
Old 05-14-2008, 09:16 PM   #3 (permalink)
roadflare16's Avatar
Member Number: 41558
Trader Rating: (20)
spark blowout? regap the plugs? in any case, sounds like spark related, start checking/replacing ignition stuff, maybe the coil?
roadflare16 is online now   Reply With Quote
Old 05-14-2008, 09:20 PM   #4 (permalink)
DrmCtchr's Avatar
Member Number: 38971
plugs then wires then coil pack.
David
DrmCtchr is offline   Reply With Quote
Old 05-15-2008, 06:05 AM   #5 (permalink)
dasmopar's Avatar
Member Number: 6413
Trader Rating: (148)
Ever run leaded gas in the car? Mod list? MSD coil?
dasmopar is offline   Reply With Quote
Old 05-16-2008, 08:21 AM   #6 (permalink)
1LAPSRT's Avatar
Member Number: 38267
Trader Rating: (19)
I'm guessing that by now you figured that this is a spark related issue!
Heading for a new track? Just want to improve your times at a track you already run?
Old 05-17-2008, 06:51 AM   #7 (permalink)
Elected Moderator
stowaway's Avatar
Member Number: 3286
I was gonna say the car just hates boost + big load + low rpm, lol.
Old 05-28-2008, 04:47 AM   #8 (permalink)
pdqsrt4's Avatar
Thanks everyone for the input.
I have the NGK Iridium IX Spark Plugs LZTR6AIX-13 gapped @.050. Only mods on motor are K&N air filter and the MOPAR Borla exhaust.
I cleaned up the factory spark plugs and regapped then to .050 and put then in. NO PROBLEMS!
Should I keep using the NGKs (with a smaller gap) or use the factory ones?
If I should use the NGKs, suggestions on a gap?
Thanks
Old 05-28-2008, 04:55 AM   #9 (permalink)
Nelson's Avatar
Member Number: 52787
Smaller gap for sure. Put them down to .035 and see if the problem still happens.
Stage Slow...
It's gone... Back to Stock For Realz
Nelson is online now   Reply With Quote
Old 05-28-2008, 08:02 AM   #10 (permalink)
1LAPSRT's Avatar
Trader Rating: (19)
I run my Denso ITV-22's at .032
Old 05-28-2008, 09:38 AM   #11 (permalink)
htheduck's Avatar
Member Number: 10205
Doug,
Curious-> why that model Denso plug? ...the website indicates ITL16 for a match to the SRT-4.
-Howard
_________________________________________________
94 Taurus SHO: K&N, Eibach/Koni, ATE Super Blue, FPS: Alum SFB, SFC, 96 Brakes/Porterfield R4
94 Integra LS: K&N, Neuspeed/KYB, F&R STB, Rear LTB
04 SRT-4
htheduck is offline   Reply With Quote
Old 05-28-2008, 11:56 AM   #12 (permalink)
1LAPSRT's Avatar
Trader Rating: (19)
Quote: Originally Posted by htheduck View Post
Doug,
The ITV 22 is the irridium, and 2 steps colder than the "normal" plug.
Old 06-14-2008, 11:15 AM   #13 (permalink)
pdqsrt4's Avatar
Ok, so when I regapped the NGK Iridium IX Spark Plugs LZTR6AIX-13 to .035 the problem went away.
Why does this plug need a smaller gap than the stock plugs?
Does anybody else using these plugs need the smaller gap also?
Thanks
Old 06-14-2008, 02:20 PM   #14 (permalink)
DrmCtchr's Avatar
for some reason rare earth metal plugs and electronic ignition dont get along. use regular old champions. or deal with the smaller gap and pay more each time. There is regular old plugs in the racecar. None of these 'spend more for this stupid feature that does absolutely squat' plugs have done much more than created a headache for me. good luck.
D
Page generated in 0.19514 seconds with 11 queries
