Here is the deal jason. The front of this car sucks for not bing able to have to much Caster. You have to realize that by increasing the camber, you have to have a good in between with the caster setting on the car.
These cars only have like maybe 3 deg max of caster on it. (SHITTY)
If you could up in caster, it will change the geomotry enough to not kill the inside of your tires. But for now, you should back it off to about 2 deg - camber in the front. And try to add a little toe out in the front, like a 1/16".
Remember to put something on the drivers side simulating your wheight when doing the adj's.
