Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Racing Discussion > Autocross/Road Racing
Old 06-11-2009, 12:20 PM   #1 (permalink)
FallenAngelHIM's Avatar
Member Number: 65943
Default Brake Cooling Ducts via Fog Lamps
Is it possible to remove the fog lights and use the port as a brake cooling duct? Anything I would need to make this work?
I'm speaking for road racing application, not DD.
"loyalty first, all the bullsh--- second." -Obie Trice
"DON'T STREET RACE. There's nothing to be gained except carnage." -Russ Oasis
Quote: Originally Posted by Wongfu View Post
Well the only thing that failed is you bi or whatever orientation is. Did I ask hey all you gender confused people please come fill my thread with crap?...with that being said go piss off and hump some other dudes leg
Visit my Examiner page for automotive articles.
FallenAngelHIM is offline   Reply With Quote
Old 06-11-2009, 04:16 PM   #2 (permalink)
T4EaterJonny's Avatar
Member Number: 54334
I know there's one on the white racing srt4...
1Lap SRT made his, so I imagine its a home depot racing mod thing.
here's 1lapsrt's car
Its all about performance, thats the name of the game, I pump up my tires and I oil my chain.
T4EaterJonny is offline   Reply With Quote
Old 06-11-2009, 04:38 PM   #3 (permalink)
I was thinking more of taking the fog lamp out and using that cavity to pipe something to the brake rotors.
Old 06-11-2009, 05:21 PM   #4 (permalink)
rosejm's Avatar
Member Number: 33812
You can, using similar flexible pipe.
The issue with using the fog light holes comes down to aerodynamics. There simply isn't any flow and you won't get the kind of cooling you want. The air is flowing across the openings rather than into them.
This was confirmed both on a computer and in real-life application.
If I were going to do it, I'd go with 1lap's setup as he's got a ton of testing (and racing) on it...
rosejm is offline   Reply With Quote
Old 06-11-2009, 08:20 PM   #5 (permalink)
Thanks guys.
Old 06-11-2009, 08:28 PM   #6 (permalink)
hercfe's Avatar
Member Number: 19255
i've been considering this as well... fallen, one thing to consider is with autox, cooling ducts may put you into a higher class.
hercfe is offline   Reply With Quote
Old 06-11-2009, 08:33 PM   #7 (permalink)
HCCAFan's Avatar
Member Number: 35768
Trader Rating: (23)
No airflow as said. Pissing in the wind.
WTB: 96-07 Nissan Pathfinder parts;
Hood
Left front fender
Left headlight
Radiator
Condensor
Bumper Cover
Grille
HCCAFan is offline   Reply With Quote
Old 06-11-2009, 08:36 PM   #8 (permalink)
hercfe's Avatar
remember that dude who made the front splitter out of fiberglass/plywood that had an integrated brake duct built into it? it was sick, and the most functional design yet. didn't rfr make something like that too?
Old 06-12-2009, 09:30 PM   #9 (permalink)
SRTforums Junior Admin
stowaway's Avatar
Member Number: 3286
in autocrossing you don't need ANY cooling. You won't be able to get enough heat in the brakes to even think of causing brake fade. For road course use I would look into a setup that draws air from just under the front lip. a 1.5 to 2" tall by 8" long box would draw more than enough air into a duct to let you cool things down. One thing you do need to look out for is overcooling the brakes and cooling them unevenly. I know some members here have had that happen and had to reposition their ducts to get things more even across the whole rotor.
Old 06-17-2009, 06:35 PM   #10 (permalink)
DrmCtchr's Avatar
Member Number: 38971
read post at:
so I finally got brake cooling ducts installed for Road America this weekend~
should help
DrmCtchr is offline   Reply With Quote
Page generated in 0.16347 seconds with 13 queries
