Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > SRT-4 Racing Discussion > Autocross/Road Racing
Old 03-19-2009, 03:39 AM   #1 (permalink)
uturner's Avatar
Member Number: 13844
Default Autocrossing setups??
What's your autocrossing setup? I have a new suspension kit and I need help in knowing what setup is best to go with. I currently have BC racing coilovers with camber plates., hotchkis front and rear sway bars, all on stock tires/rims. I would like to know what setups do other autocrossers run, as far as camber alignments to sway bar settings, and especially dampening setting on an adjustable dampening coilover.
thanks in advance
uturner is offline   Reply With Quote
Old 03-19-2009, 08:15 AM   #2 (permalink)
SRTforums Junior Admin
stowaway's Avatar
Member Number: 3286
max camber in front, 1/8" toe out, 0.5° less camber in the rear, adjust damping to suit your driving style and car balance. If you're still understeering on corner entry stiffen the rear. If you understeer on exit soften the front. If you still understeer on exit or have trouble getting power down go to a stock front swaybar. Run the rear at race setting. This will get you into a very close ballpark on things, adjust toe and stuff to get the balance you want.
Old 03-24-2009, 07:56 PM   #3 (permalink)
crkscrew's Avatar
Member Number: 50958
I have the inverted BCs and the hotchkis bars front and rear.
Run the front dampers at 8
Rear dampers at 1 (hardest)
have the rear sway bar in the second notch.
Front end is 2 degrees camber 1/8" toe out
Rear is 1/2 degree camber zero toe.
I do not run street tires though. I am running hankook z212 245/40/17 on a 8" enkei rpf rim.
This setup produced one fastest cars at our first autocross event last sunday.
Just remember - no matter where you go, there you are.
crkscrew is offline   Reply With Quote
Old 03-24-2009, 08:56 PM   #4 (permalink)
rosejm's Avatar
Member Number: 33812
I won't bother to write it out again as I'm running the same parameters on my stock setup.
rosejm is offline   Reply With Quote
Old 03-30-2009, 12:19 AM   #5 (permalink)
Zero_psi's Avatar
Member Number: 71591
how much hp and what other mods do u have or do u think is good for autocross events?
stage 1 with some other goodies
Zero_psi is offline   Reply With Quote
Old 03-30-2009, 02:53 AM   #6 (permalink)
uturner's Avatar
I just got my Autocrossing setup. I will try it out next event in one week.
engine: AEM intake, ignition (coilpack, wires, plugs)
Suspension: BC racing coilovers, with all camber plates, PWerks strut tower bars, hotchkis swaybars.
Wheels: Stockers on BF Goodrich KDW2
Alignment.
front: -3.00 camber, +1/8 inch toe out
rear: -1.5 camber, -1/16 inch toe in
going to put rear sway on racing setting.
Tires, I'll probably pump em up to about 38-40psi
thats it. yay!
Old 03-30-2009, 01:58 PM   #7 (permalink)
rosejm's Avatar
Frankly, I think there's plenty of power with a stock setup. The trick is to get enough tire to put that power down.
The single most important part is the driver (seat time). Then tires (maybe 25% as important as the driver), then car setup (very small part) THEN mods (minuscule portion of the equation).
And at the end of the day, modifications will likely move you to a class where you won't be competitive unless you've completed most (if not all) of the modifications allowed for that class.
Old 04-12-2009, 01:00 PM   #8 (permalink)
RedlineRacer4's Avatar
Member Number: 40182
just got done doin my first ever autocross event yesterday... amazing. now i'm lookin for some sway bars looks like hotchkiss is the way to go?
didn't want to start a new thread so i'm searching
RedlineRacer4 is offline   Reply With Quote
Old 04-12-2009, 02:37 PM   #9 (permalink)
Member Number: 50098
I have the SM setup as follows:
Stage 2 /w toys
Stage 3 Coils -1.5 front -1.0 rear
Hotchkis front and rear
DC strut tower braces front and rear
Rear tensioners
all Poly bushings
Solid MMs and trans mount
Mopar Exhaust
Mopar Short throw shifter
Mopar BOV (plate)
Mopar CAI
Hahn Racecraft FMIC
Tweaked the boost to 21 spike 19 hold on stock turbo and I run BFG R1 slicks on 17x7.5 rims. I can beat most SM guys, only have a hard time with exceptionally well setup evos/stis.
I might be missing a mod or two, but is the just of it. You get the picture.
SRT4Void is offline   Reply With Quote
Old 04-13-2009, 02:28 AM   #10 (permalink)
uturner's Avatar
nice setup. Which poly bushings did you go with?
Page generated in 0.16251 seconds with 13 queries
