No question that 26 by 8.5 is too big for 90 percent of the SRT-4 apps. I would go with the 24.5 by 8.2. If your spinning the slick you need to work on your burnout or your track is not prepped correctly. When I was running mustangs in the late 80s the 26 x 8.5 netted me 1.5 shorts at 11 flat so that size is very capable at about 11 psi. Its just too tall for the SRT. You will lose 3-5 mph if you arent running in the 400 whp range or higher.
Now a taller tire is almost equivalent to a taller gear. Forced induction cars love tall gears, as it gives them more work to do, thus increasing the MPH at the trap. I've seen this myself. Are you suggesting that the "sweet spot" for the srt happens better with the 24.5? I could almost go for that, but I think with a properly tuned S3 car, the 26 would add MPH, but possibly slow down the short time.
04 Stage III w/t, AGP WGA, TXS MBC, AEM I, Mopar BOV, Mopar DP, Mopar exh.
so with the 24.5 inch tall slicks are you having to shift to 5th gear? i have run my car with the stock tires adn i ran a 114mph i'm in serious need of slicks but don't want to have to go to 5th or go so small that i will over power them i'm rihgt aroud the 400 hp mark.
s1, stock turbo, power paq, needswings dp, custom intake, custom cold side pipes, agp wga, ngk plugs, magnacore wires, direct port 100 shot, aem wb a/f of 11.5-11.8, custom intake mani, direct port water injection, 255 pump, second fuel system for nitrous with return line and fpr, 12.3@116 2005 pt cruiser
currently running 26/8.5/15 m&h slicks on k1's....stock turbo no n2o 296whp 364wtq....pulled my best 60's 330's 1/8th's 1000ft's and 1/4's....car is way more consistant now. MPH is off only from 1/8 -1/4 about 1mph but the consistancy is un matchable so far. 1.672 60is best and 11.87 best 1/4 115.37 being best mph to date.
Fastest stock turbo no n2o in the country.
Best 60 1.662
Best 1/8 7.55/93
Best 1/4 11.865/116
Best MPG 28.1 city/33 highway
I remember reading a post from Dr. Who about using different size slicks on the lightweight stage 3 car. Raced the Stage 3 PVO car tonight There is the post. On 22" slicks they were able to trap 121 a couple times. On the 24.5 the trap speed didn't slow down that much (less than 1mph), but lower the ETs. Not sure if they ever ran a 26" slick, but it would be interesting to see the results.
Also with the 24.5" slicks you would not need to shift into 5th gear unless you are trapping 130ish
yeah i have the 26 8.5 x 15 ..i think the tire is to wide mine rub on my shock i have to run a spacer so it wont rub ... my next set is gonna be 24.5 x 8 15 .. the 8.5 is to wide...
i also have a prob spinnin with the 26 x8.5 x15 in 1st gear ...i launch the car at 3000 rpm i run 14lbs in the tires .... im ruffly at 26lbs of boost
my whp is at about 340 on (pump gas) 390 on (race fuel)...
also i can not get the tires to smoke alot.....i start doing my burn out the tires get a lil sticky and the car pulls me out of the box with me pullin up on the e- brake i just cant get the car to sit and get the tires really sticky at all .
[quote=smokd u2]yeah i have the 26 8.5 x 15 ..i think the tire is to wide mine rub on my shock i have to run a spacer so it wont rub ... my next set is gonna be 24.5 x 8 15 .. the 8.5 is to wide...
Just for reference, what wheel are you running? Stock strut or coilovers?
