View Poll Results: What is your WHP to turn the 26x8.5x15 slicks
250-300 7 6.80%
300-350 13 12.62%
350-400 22 21.36%
400-450 19 18.45%
450-500 16 15.53%
500-550 6 5.83%
550-600 5 4.85%
I am nutz 15 14.56%
Voters: 103. You may not vote on this poll
Old 11-10-2005, 06:07 PM   #1 (permalink)
SRTforums Nazi Admin
NIVO88T's Avatar
Member Number: 1109
Default Who runs the 26x8.5x15 Slick size succesfully
Making a poll to help others here choose the right tire before going to these slicks.
If you are under the 400-450whp the 24.5x8.5x15 might be your best bet.
NIVO88T is online now   Reply With Quote
Old 11-11-2005, 08:05 AM   #2 (permalink)
NIVO88T's Avatar
Member Number: 1109
bump, we have 1 voter
Own a Rear Wheel Drive Nissan/Datsun or Infiniti?
www.RWDNissan.com
SRTGURL's SRT-4 SIte:
www.srtgurl.com
Old 11-11-2005, 08:20 AM   #3 (permalink)
MikeCandler's Avatar
Member Number: 5521
Trader Rating: (52)
I have too agree with you on that one! I mean you can certainly use the 26 at that level but I really do not think there is any performance advantage to it when you can cut 1.7 or better 60 foots on the 24.5 at that power level
Mike
2007 Subaru WRX stock with some Buschur Racing parts
MikeCandler is offline   Reply With Quote
Old 11-11-2005, 09:04 AM   #4 (permalink)
mchat's Avatar
Member Number: 3809
I'm actually running a Hoosier 26x8 (spec'd as 8.1 tread width) not a 26x8.5.
More than 400whp is a bit too much in 1st gear; I spin through 1st gear to a 1.7 60' though.
I've had my best results running ~22-23psi in 1st. At 26psi I was getting mid-high 1.8's and 30psi in 1st = 2.1 60'
2003 SRT4 - Latrodectus: "Lightly" Modded...
mchat is offline   Reply With Quote
Old 11-11-2005, 09:09 AM   #5 (permalink)
SRToc Member
Turbo Jeff's Avatar
Member Number: 1311
Trader Rating: (17)
i had 26 inchers and with 333whp they were too big. im going to get 24.5 or maybe even 23's next time.
Turbo Jeff is offline   Reply With Quote
Old 11-11-2005, 09:23 AM   #6 (permalink)
Member Number: 873
how do you know when they are too big?? also dont they make the gearing longer so to speak....i think the car could use a slightly longer final drive....especially first gear.
2005 A4 GTO....intake, headers, exhaust, vtach and nawwwz..
2003 srt-4 SOLD..
blacksrt4u is offline   Reply With Quote
Old 11-11-2005, 09:39 AM   #7 (permalink)
addictedtosin's Avatar
Member Number: 30537
Trader Rating: (113)
No question that 26 by 8.5 is too big for 90 percent of the SRT-4 apps. I would go with the 24.5 by 8.2. If your spinning the slick you need to work on your burnout or your track is not prepped correctly. When I was running mustangs in the late 80s the 26 x 8.5 netted me 1.5 shorts at 11 flat so that size is very capable at about 11 psi. Its just too tall for the SRT. You will lose 3-5 mph if you arent running in the 400 whp range or higher.
Basically it looks like this minus a turbo...... oh and wheels too
addictedtosin is online now   Reply With Quote
Old 11-14-2005, 12:28 PM   #8 (permalink)
skipdogg's Avatar
Member Number: 18045
the 26x8.5x15 M&H hooks up great on the WhiteMtnSRT4. several 1.69 60 foots were had.
edit: he is making 414 hp, and 470 ft lb.
skipdogg is offline   Reply With Quote
Old 11-14-2005, 12:31 PM   #9 (permalink)
SRToc Member
Turbo Jeff's Avatar
Member Number: 1311
Trader Rating: (17)
worth mentioning that he has over 400whp though.
Old 11-14-2005, 12:53 PM   #10 (permalink)
NIVO88T's Avatar
Member Number: 1109
bumps
Old 11-14-2005, 12:55 PM   #11 (permalink)
Member Number: 2345
hmmmm, might be the cause for our low traps. even though we 60' in the 1.7-1.8 range...
might have to experiment next season...
BlackDragon is offline   Reply With Quote
Old 11-14-2005, 02:11 PM   #12 (permalink)
SRToc Member
Turbo Jeff's Avatar
Member Number: 1311
Trader Rating: (17)
my thoughts exactly with my car. 112.xx mph trap with stage 3 i was expecting 114 or so. Next season I'm going to try 24.5 or maybe 23 if I can find them.
Old 11-14-2005, 02:19 PM   #13 (permalink)
Member Number: 5521
Trader Rating: (52)
I think a 23 is going to be too small, even on a stock car the 24.5's seem to be the best match in regards to traction and gearing.
Old 11-14-2005, 04:10 PM   #14 (permalink)
SupeRfasT-4's Avatar
Member Number: 24103
Trader Rating: (20)
I have 24.5/8.5/15 ordered 26 and everyone recommended a 24.5 so I went with that, I talked to the guy from M&H tires and he said a stock car is ok with 23, but modded should go with 24.5, and now i have them sitting in my room waiting for the rims to come.
Nikon D80 Photog
SupeRfasT-4 is offline   Reply With Quote
Old 01-13-2006, 09:33 AM   #15 (permalink)
Member Number: 10255
Trader Rating: (47)
Yes this is true, their is that fine line going from the M&H 8.5/24.5-15 to the 26" tall. What I see is that once you hit that 450whp to the 470whp and you have the set up down to a T, it's time to get the 26" Tall Slick. This is info that the racers give me on the phone. I hope this helps, and DO NOT forget your SRT DISCOUNT GUY'S for the slicks.
Happy New Year everybody and be SAFE.
John@M&H
www.mandhtires.com
Buy Direct and SAVE (Your Source For M&H Slicks & Dot ). Give us a call @ the M&H Warehouse 661.324.4773
SlicksMH is offline   Reply With Quote
