View Poll Results: What is your WHP to turn the 26x8.5x15 slicks
250-300 9 8.57%
300-350 13 12.38%
350-400 22 20.95%
400-450 19 18.10%
450-500 16 15.24%
500-550 6 5.71%
550-600 5 4.76%
I am nutz 15 14.29%
Voters: 105. You may not vote on this poll
Old 10-08-2007, 10:03 AM   #46 (permalink)
Checksum's Avatar
Member Number: 19673
Quote: Originally Posted by Hayabusa
Just watch those wheel studs, I break them left and right running nitrous off the line. I think every sub 1.65xx run has broke a wheel stud.
amen to that. have arp's sitting at the shop waiting for next season when we break the rest of mine off. I have gone through 8 I think. Good thing we had a gt-cruiser parts car
Checksum is offline   Reply With Quote
Old 10-10-2007, 03:41 PM   #47 (permalink)
Member Number: 58313
Can you guys fit the 26x9x15 Hoosiers? I've had good results with them out of the box - I couldn't fit the 10" MTs so the Hoosiers were my best intermediate bet. Good life as well, they wear much better than the M&Hs.
'93 Ford Probe GT - a few mods...
10.71 @ 133.8 mph [16 psi] - Timeslip
468whp, 412 wtq @ 20psi - Dyno sheet
Dan [Sac] is offline   Reply With Quote
Old 10-10-2007, 11:11 PM   #48 (permalink)
Checksum's Avatar
it's not recommended on a 7" wide rim, if you had an 8" wide you should be able to run them, might have to roll the fender a little tho... Ideal would be a 24.5x10x15 for our cars, but no one makes rims unless you buy bogarts.
Old 10-11-2007, 04:56 AM   #49 (permalink)
Hayabusa's Avatar
Member Number: 31537
I will stick with M&H they have done me well.
Wanna race a cop? Click here: http://www.tnbeattheheat.com/
Hayabusa is offline   Reply With Quote
Old 10-20-2007, 06:12 PM   #50 (permalink)
Member Number: 8030
can i fit 26x8.5x15 on my rota slipstreams? i am running a spacer. right now i am running m/t e.t. 22x8x15 but i am about to be pushing the 450whp mark and i think i need somthing bigger
2003 srt-4; quickwhips 50 trim .63 ar, QW FMIC, 3 agp mm, ACT 6 puck clutch and flywheel, agp CAI, agp hard pipes, agp custom spark plugs and wires, turbo xs BOV & MB, s2 no toys, custom built 3 in. stainless steel turbo back ( inc o2 housing ) side exit cat-less exhuast, walbro 255, MT E.T. slicks, some carbon fiber accents.
1998 Lincoln Navigator
2001 Land Rover Discovery
All paid for
fastsrt4racer is offline   Reply With Quote
Old 10-21-2007, 08:39 AM   #51 (permalink)
Checksum's Avatar
if they are 15x7 or wider you should be fine.
the biggest problem with 26" tall is the strut tower brace. If you have CO's (at least in the front) you should be fine.
Old 10-22-2007, 01:47 AM   #52 (permalink)
Member Number: 8030
I have stock suspension will they still fit?
Old 10-22-2007, 11:15 AM   #53 (permalink)
Checksum's Avatar
mine didn't. maybe the spacer will give you the room you need, who knows.
Old 11-13-2007, 03:26 PM   #54 (permalink)
Ram48's Avatar
Member Number: 31250
John at M&H recomends the 26 in x15x8.5 at 450 hp and up. We are on24.5 and just ran an 11.2 at 123 mph See vid (shawnturbo)..
We have ordered the parts to allow us to mount 13inch rims and will go with 26x8.5x 13s next season It should make a huge difference with the taller sidewall.
500/510 11.25 @ 123 AGP hp61 bb .82ar s5 w/ S comp. housing,LFS 60mm tb ,DASported intake Needswings dp ,M&H slicks, Boomba eng. & trans. mounts, PSI-FI traction bushings,tien coilovers, BC S2cams, Fidanza gears, water/meth. inj.Nemo's hydr. tob,ACT 6puck ridgid,NDE tcs, DSS stage 5 axels, D-TEC fc/bc & tuner/wideband
Ram48 is offline   Reply With Quote
Old 11-24-2007, 11:46 AM   #55 (permalink)
Member Number: 38644
I run 26" mickey thompson full slicks on my SRT and I DEFINITELY don't make 400hp .. I run 12.3 @ 110 with stage 1, stock turbo, and the usual fuel mods and bolt ons. I have yet to dyno the car, but I would guess slightly over 300hp. I get 1.7 60fts consistently (pic below)
I have run the car on 24.5's but I just blow up first and second gear .. I love the 26's.
BoyBeaterTsi is offline   Reply With Quote
Old 12-14-2007, 05:49 PM   #56 (permalink)
Ram48's Avatar
Quote: Originally Posted by Turbo Jeff View Post
my thoughts exactly with my car. 112.xx mph trap with stage 3 i was expecting 114 or so. Next season I'm going to try 24.5 or maybe 23 if I can find them.
unless you are bone stock the 23 will be too small even stock they may be. Guys all you need to do is call John at M&H he is a vendor here and will gladly tell you all you need to know about what slicks to run on our cars according your mods.
We are goinfg to 13 inch wheels with 26x8.5x13 slicks but we dyno at 500hp and 560ftlbs. and our 24.5 on koseis are for sale if anyone is interested. mounted and bal. with tubes . we have cut a 1.68 and 1.70 with them on the stock turbo. and ran the 11.22 @ 123 with a 1.8 60 on the big turbo
Old 12-24-2007, 02:05 PM   #57 (permalink)
Member Number: 39105
To give you some insight on fitment, last time I was out, I ran a friend's 24.5 X 8 X 15 M&H slicks on a 1/8" spacer. I'm on a SOHC neon, where the spring perches sit 3/4" lower. That means a 26" is 1.5 inches taller, .75" on each side, which should be the tallest to fit under an SRT's stock struts. Side note: 3 year old 24.5" tires netted me 1.71 60' times.
esteinmaier is offline   Reply With Quote
Old 04-18-2008, 01:27 PM   #58 (permalink)
FraziersSRT's Avatar
Member Number: 37867
Trader Rating: (34)
Good info in here,keep it coming!!
FS : RC 650's $200.00 SHIPPED!!
http://www.srtforums.com/forums/f27/...5/#post6142045
FS : Mopar Turbo Back Exhaust w/cutout!! $350.00!!
http://www.srtforums.com/forums/f27/...8/#post6171626
WTB : FIDANZA CAM GEARS AND 44LB S3 TURBO - PM ME!!
FraziersSRT is online now   Reply With Quote
Page generated in 4.79985 seconds with 12 queries
