Old 07-28-2006, 07:04 PM   #1 (permalink)
oshawa SRT's Avatar
Member Number: 12117
Trader Rating: (36)
Default who actually uses tubes in their slicks?
Hey, I have a set of slicks on the way and always have in the back of my mind purchasing tubes for the safety concern. But out of the 30+ FWD slick cars I see at the track on a given night not one of them run tubes? Is it really required for safety, or should you use them once you are over a certain trap speed or somethin?
thanks
oshawa SRT is offline   Reply With Quote
Old 07-28-2006, 07:23 PM   #2 (permalink)
Member Number: 14585
Trader Rating: (19)
How would you like a tire to blow out at 100+mph? I bought them for safety.
bigdoggsrt4 is offline   Reply With Quote
Old 07-29-2006, 12:32 PM   #3 (permalink)
4SRT4's Avatar
Member Number: 19538
For real.
4SRT4 is offline   Reply With Quote
Old 07-29-2006, 08:04 PM   #4 (permalink)
ChriSRT-4's Avatar
Member Number: 12943
Trader Rating: (12)
For real.
X2...
ChriSRT-4 is offline   Reply With Quote
Old 08-03-2006, 12:46 PM   #5 (permalink)
canadian_made_srt-4's Avatar
Member Number: 22368
Trader Rating: (29)
I have had a tire go out on the HWY ay 120kmph and it was not bad at all. Are you guys going off experience or what M&H and M/T say on their sites.
1. m/t and M&H want to make $$ buy sellgin tubes
2. these tubes are ment for drag wheels only and will not fit with out mods
3. drilling aluminum or steel wheels will cause more of a safety issue then not running tubes
4. when a FWD car launches it takes the weight off the drive wheels greatly reducing stress. with a RWD car nearly 3000lbs of weight rest solely on the rear tires thus requiring tubes for safety
5. A slick will not just blow out unless there is debris on the track and in this case a slick is thin and the debris will not only cut the tire but it will!! cut the tube too.
6. if the tire ever spins on the rim witch happens sometimes when you are not running beadlock the tube will rip appart and will require a tire shop to install a new tube where as with no tube the tire slips and a. it wont go flat or b. all you have to do is fill it with air again.
7. these things are $100can each and weigh 6lbs each
All this info is hard facts from a guy that owns a tire shop and has two drag cars him self that run quite a bit faster then the srt's on this site his camaro ran a 8.28 this past weekend and his nova runs in to the 7's oh and he dosnt run tubes either. He sells more M/T slicks in Ontario then any other dealer and sells tones to FWD drag cars I know two guys with civics that run mid to low 10's and they also do not run tubes.
hope this info helps
543WHP HIGHEST WHP PUMP GAS SRT-4 IN CANADA
canadian_made_srt-4 is offline   Reply With Quote
Old 08-03-2006, 12:51 PM   #6 (permalink)
Trader Rating: (29)
forgot to say on a 15'' rim the valve stem if put in the center of the rim will hit the caliper or rub on the disc's you would actually have to dril the holes with the rim on the car and even then the hole will not be in the center and if the tube is twisted inside the rim it will fail.
Old 08-21-2006, 12:34 AM   #7 (permalink)
DDogsrt461BLK 3.0's Avatar
Member Number: 32500
Trader Rating: (17)
How many of you guys are running tubes, in your slicks??? Speak up, I've got to hear a few opinions on this!!!!
Stg3 toys, ported head & intake, NX 4nozzle, progresser, wide ban, egt, fuel pressure, injen, samco, Mpx3", Maxxfab02,Greddy CC, Boomba's, AIS intercooler, STS, billet SS, .020 8-1 JE's, Eagle 4340 H beam rods, UDP, you name it I've done it Mopar Clutch
Don't be messing with my FJO!!!!
2 180+ Lph pumps feeding the bitch!!!!
DDogsrt461BLK 3.0 is offline   Reply With Quote
Old 08-21-2006, 01:10 AM   #8 (permalink)
srt4101's Avatar
Member Number: 38341
When I blew a tire at 110mph I just pulled over and put the spare on
srt4101 is offline   Reply With Quote
Old 08-21-2006, 03:44 PM   #9 (permalink)
LOW ET's Avatar
Member Number: 29852
i have tubes in my slicks, just for the added safety
LOW ET is offline   Reply With Quote
Old 08-21-2006, 10:49 PM   #10 (permalink)
XxRedDevilxX's Avatar
Member Number: 25941
i trap 110+ on 26 inch mt with springs for suspension. no tubes here
XxRedDevilxX is offline   Reply With Quote
Old 08-22-2006, 10:57 PM   #11 (permalink)
Trader Rating: (29)
There is no added safety with tubes in a FWD car only on high horse power RWD cars and I mean like 500hp+
Old 08-31-2006, 09:24 AM   #12 (permalink)
RTst's Avatar
Member Number: 2464
Trader Rating: (28)
No tubes here
RTst is offline   Reply With Quote
Old 08-31-2006, 02:35 PM   #13 (permalink)
project95rebuild's Avatar
Member Number: 35013
no tubes here either
-95 dodge neon coupe 11.91 @ 119.05 16psi tuned.
best 60ft = 1.68 ; best trap is 119
2/28/08.. Thanks to some PTP parts
16psi 352whp and 336wtq
22-23psi 415whp and 393wtq
PICS http://www.cardomain.com/ride/2153867
-05 reg cab hemi 14.65 @ 90.34 no tailgate, no spare, no air filter... BONE STOCK
project95rebuild is offline   Reply With Quote
Old 08-31-2006, 06:58 PM   #14 (permalink)
XXxx_Totmacher_xxXX's Avatar
Member Number: 9649
Trader Rating: (38)
I have tubes, but not installed, I got them just like you said for safety, but the shop was going to have to do surgery on my Kosie K-1's for them to fit. 1) the tubes have like a serious 13" ID, they had to go through hell and back to get them on. 2) like said before you have to drill out the rim. So yeah if anyone wants to buy 2 slicks (one still in package) PM me.
_
Neon SRT-4
11.431 @ 123.61_____417 Hp / 450 Tq
Caliber SRT-4
12.782 @ 111.09_____407 Hp / 460 Tq
Tuned By Totmacher
_
XXxx_Totmacher_xxXX is offline   Reply With Quote
Old 03-18-2008, 06:20 PM   #15 (permalink)
ReDsRtKiD's Avatar
Member Number: 46248
Trader Rating: (10)
I have Kosie K-1's and just put my 26 inch slicks on w/ tubes. The valve stem doesn't go completely through the hole, but more than far enough for me to screw the valve cap on. Is this safe or should I take the tubes out? Anyone running a similar set-up?
(Old Set-up) BB .50 Trim
12.8 @ 118 Traction>Me
(New Set-up) HTA35R+EMS
11.8@114 Breaking up through 4th
60' 1.70 1/8 7.6@95
ReDsRtKiD is offline   Reply With Quote
» Search Used Cars
