Old 03-29-2008, 02:46 PM   #1 (permalink)
Member Number: 53240
Default Very bad time at the track<..
ok i got a 05 with stock axels 41k on car..first time ever at the track yesterday and first run..i ended up snaping a axel..i have the race motor mount inserts and when i put them in..i torqued them to specs (85lbs)..i didnt use locktite..the top motor mount poped out,bottom one stayed in..i brought it the the shop and today the mechanice said he had to tap and dye the top mm bolt and use a longer one,cause the stock one was on in there about 1/2 inch wtf!..i thought u can use the stock bolt when u use the mm inserts..so he fixed that..alltogether i need..mm bolt,axel,fix coolant lines some of them got punksured..and the cold side pipe popped of the throttle body..so tell me how much my mechanice will charge me for all that..and tell me is that normal for the top mm to pop off??
Its Don D. u know me<<......
60':2.340
1/4:14.279
mph:96.85
MODS:
ill put it this way..the f*cking car will never be fast enought for me!! lol
Killasrt444 is online now   Reply With Quote
Old 03-29-2008, 02:49 PM   #2 (permalink)
btw i launched way wrong..i have 225/40/18 street tires at stock aire pressure..i got nervous at the light and dumped the clutch at 2500 rpms and got alotta wheel hop and gave and to much throttle and by the time i shifted too second it was to late
Old 03-29-2008, 03:00 PM   #3 (permalink)
missionsk8r21's Avatar
Member Number: 56407
Trader Rating: (21)
Never heard of the mount popping out, but obviously locktite would've prevented that. Solid motor mounts would've helped to fight wheel hop alot better then the inserts. And for the coldside pipe popping off, always boost leak test and check everything before a day at the track. Mechanics are all different, but I cant imagine that would cost much. O and driver mod would always be a good thing.
05 ACR - Full bolt-on SSTv2.5 - SOLD
Current:
02 WRX with STI swap + 20g turbo + bolt-ons
02 GSX-R 600
missionsk8r21 is offline   Reply With Quote
Old 03-29-2008, 04:48 PM   #4 (permalink)
fivetoez's Avatar
Member Number: 9691
You've got to learn how to launch these cars or you'll tear em up every time.........Ease the clutch out, don't dump-it.
_____5TOEZ______ 1967 Cadillac Calais 429 2dr., 1967 Chevelle 4sp. Conv. ,1978 Dodge 318 "Factory Custom"van., 2004 Dodge Srt-4,Stage.1(E-Blue) & a couple motorcycles.
fivetoez is online now   Reply With Quote
Old 03-29-2008, 09:17 PM   #5 (permalink)
yea i def need to learn how to launch the car before i hit up the track again..my mechanice said the top stock motor mount bolt wasnt long enough,so he put a longer one in without hittint the transfer case..but when i put in the race inserts i torqed them to factory specs 85lbs and is still popped out..friggin sux..i think i wanna invest in the bwoody traction bar /h brace,i hear that totally eliminates wheel hop
Old 03-29-2008, 09:36 PM   #6 (permalink)
kotu100's Avatar
Member Number: 4357
roll into the water box and spin the tires just once, move out of the water box and spin em till they squeal. launch about 1800-2200rpm feathering the clutch and make sure in 1st you don't smash the gas pedal to the floor u gotta "roll" it down, a nice steady acceleration. shifting into 2nd comes at about 5800 rpm, DO NOT WOT SHIFT 2ND, however WOT into 3rd+4th is fine. and the tire pressure does better around 22psi in front and 40 in the rear
Best run:12.167@113.93 mph with a 1.82 60'. same mods as below w/ 110octane on 24x8.5x15 MT drags.
Best Run on streets: 12.571@114.61 mph with a 2.0 60' on 18" all season tyres. mods=AGP WGA, S-AFC I, 750cc inj., HKS BOV on ATP UPP, Mopar sts, AGP dogbones, CCA FMIC, and 3" turboback no cat no mufflers.
Best MPH was 116.40 run with same mods as above!!!
Tuned by ME: 286whp 366wtq 22/13 FASTEST SRT-4 ON STREET TIRES, STOCK TURBO, OFF THE BOTTLE
kotu100 is offline   Reply With Quote
Old 03-31-2008, 02:15 PM   #7 (permalink)
Member Number: 38189
are you sure your talking about an srt-4? last time i checked we dont have a transfer case, and yes you can use the stock bolt, the only upgrade i have ever seen, is a stronger bolt, not a longer one
rico's-srt is online now   Reply With Quote
Old 03-31-2008, 02:26 PM   #8 (permalink)
hmm yea..i did resuse the stock bolt..but my mecahnic said it wasnt long enough not holding much..so they put a longer one in
Old 03-31-2008, 06:15 PM   #9 (permalink)
addictedtosin's Avatar
Member Number: 30537
Trader Rating: (114)
x1232123.4....
I learned from 1badsrt-4 and Kotu100. Once you get the hang of it you wont hop one bit. Wheelhop tears up these cars fast.
12.0@120 on DRs and 93oct.
addictedtosin is online now   Reply With Quote
Old 03-31-2008, 08:41 PM   #10 (permalink)
ha yea ur tellin me it tears these cars up..friggin first time ever at track and friggin for first run i fuck my car reall good..and its my dd too at that ...i just hope my mechanic doesnt kill me on the price
Old 03-31-2008, 08:51 PM   #11 (permalink)
quicky4's Avatar
Member Number: 28222
Long ago I had motor mount inserts and the top one also popped out!!! I then went to Home Depot and bought washers to hold the inserts so they never fell out again...
682hp, 599tq
Best e/t 10.51
Best trap 138mph
100% RAGE BUILT
SRT-4 Manual 5spd record holder. Full Weight and then some.
quicky4 is offline   Reply With Quote
Old 04-01-2008, 01:30 PM   #12 (permalink)
yea my inserts have the big washers they came with..and still the top mount popped out!! wtf??
Old 04-01-2008, 01:35 PM   #13 (permalink)
Nelson's Avatar
Member Number: 52787
Just get solid MM. They aren't that expensive in comparison to other upgrades, and they'll save you a lot of money in the long run.
Stage Slow...
It's gone... Back to Stock For Realz
Nelson is offline   Reply With Quote
Old 04-01-2008, 02:15 PM   #14 (permalink)
yea i dunno about solid mm mounts cause the vibration i hear is really bad..if anything i wanna get the bwoody h-brace/traction bar setup..i hear that gives u no vibration or wheel hop
Old 04-01-2008, 03:20 PM   #15 (permalink)
trust me dude, its going to vibrate some at first, but after not even a week or so you wont even feel it, unless you turn on the a/c. then the vibration will be noticeable
Page generated in 0.19895 seconds with 11 queries
