Old 03-22-2008, 11:59 PM   #1 (permalink)
bonessrt-4's Avatar
Member Number: 17898
Default tried out my slicks
went to the track today, took it real easy because i believe my clutch is about ready to go (over 300 track runs on it).
anyway got a 12.90 @ 107 with a 1.90 60'.
i have sitting at my house a new clutch , bwoody trac bars and h-brace and 255 walbro, really need to get these installed sometime.
i ran the slicks at 16 psi , i know i need to go lower but i was playing it safe.
2004 black srt-4 ,stage 1, AEM sri,agp billet wga,prothane mm inserts,mopar perf. sts w/boogers,ngk iridium plugs, QTP 3" dp no cat electric cutout,mpx ud pulley,msd 8.5 mm plug wires,quickwhips big fmic,agp fuel return kit,aem uego wideband,dasmopar map clamp,bfg g-force DRs.
12.90 @ 107.86
newly added: mpx 62 mm tb, agp hardpipes , ptp charge pipe , ptp checkvalve , ptp upgraded spring wga , 255 l walbro fuel pump.
bonessrt-4 is offline   Reply With Quote
Old 03-24-2008, 06:36 PM   #2 (permalink)
Member Number: 10255
Trader Rating: (49)
Try dropping down 1-psi at a time and get use to it, GOOD LUCK.
John
M&H
Buy Direct and SAVE (Your Source For M&H Slicks & Dot ). Give us a call @ the M&H Warehouse 661.324.4773
SlicksMH is offline   Reply With Quote
Old 03-24-2008, 06:41 PM   #3 (permalink)
bluebeast's Avatar
Member Number: 39695
Trader Rating: (12)
You should be able to cut 1.7 sixtys with no problem if you leave harder.
ROLL RACING isn't racing. It's just 2 homos speeding next to each other!
11.79 @ 118.53 S3 + bolt-on car
bluebeast is offline   Reply With Quote
Old 03-25-2008, 06:27 AM   #4 (permalink)
bonessrt-4's Avatar
i know, i just want to take it easy until i get my new clutch in.
Old 03-25-2008, 06:55 AM   #5 (permalink)
BOOSTINSRT04's Avatar
Member Number: 33061
Trader Rating: (23)
Nice man! I usually run 11-14psi in mine, and I launch of a 2step, and i've cut consistant low 1.7 60's on the stock clutch! I've had a few 1.70's and ERABBIT23 cut a 1.68 in my car! I was runnning M&H (FTW by the way) 23" slicks on those runs, and I've stepped up to a 24.5 for this year!
04 S3 11.90@114 Untuned PCM controlled!
Old 03-26-2008, 02:57 PM   #6 (permalink)
Member Number: 37036
Trader Rating: (15)
What is your suspension set up running the 24.5s? I'm on Mopar S1 springs and stock struts and want to run 24.5 x 8.5 x 15s (on PT steelies) but I'm not sure if they'll fit.
My best on BFG drag radials was a 1.9x so I'm really hoping to drop that down to the 1.7s so I can finally hit 11s.
Mario Kovach, Administrator: Probetalk.com
2005 S3R Stone White Srt-4
USAF Explosive Ordnance Disposal Craftsman
Bomb Squad is offline   Reply With Quote
Old 03-26-2008, 07:19 PM   #7 (permalink)
Trader Rating: (23)
Stock struts, and Hotchkis springs for now! PT steelies, and 24.5s they fit good, so you should have no trouble! I launch off a 2step between 4k, and 4750 depending on track conditions!
Old 04-01-2008, 02:07 AM   #8 (permalink)
dj4monie's Avatar
Member Number: 977
John
M&H
John is my witness, I still don't know why he felt he had to talk to me though John - 12.@746@105.9 11psi in the slicks 23x7.5x15 (1.740 60ft)
He was STANDING right there so doubters -
4000-4500K and STAND ON IT! It don't spin.. I found out after replacing the tranny and clutch recently I had a MP clutch in the car...
Now S3R Powered!
dj4monie is offline   Reply With Quote
Page generated in 0.23522 seconds with 11 queries
