Quote: Originally Posted by
Sp00lin00
you need LCA bushings and a trans mount of sorts, the bwoody traction bar setup helps alot and is what i ran on my car. Be sure to do LCA bushings before bars, hope that helps
+1 on LCA bushings (prothanes), solid tranny mount (AGP), and the bwoody traction bars.
The LCA bushings made quite a difference in feel. The general verdict is that the Prothane ones are much easier to install.
If you are considering drag radials, then why not consider slicks? I'm curious as to why you've ruled them out already.
