Old 06-25-2004, 12:10 PM   #46 (permalink)
chewie's Avatar
Member Number: 5027
Trader Rating: (21)
I'm gonna buy dr's and wheels before anything else because I spin too much. Do I need to do a burnout before the run with Dr's....if so, what's the best way to do a burnout on fwd at the track?....don't wanna look too silly.
No more SRT-4 for me.
chewie is offline   Reply With Quote
Old 06-25-2004, 12:15 PM   #47 (permalink)
Member Number: 1504
woh talk about revived from the dead...
Solo II is offline   Reply With Quote
Old 06-25-2004, 02:44 PM   #48 (permalink)
SRTforums Nazi Admin
NIVO88T's Avatar
Member Number: 1109
hit the water box, spin the tires once, go up a bit...ebrake up and then rev the car up to like 4-4.5 rpms... dump the clutch and by then you should be doing a burnout. move the steering wheel left and right to distribute the weight evenly and get a good burn on the tires. Pull ebrake down and roll the car out of the burnout....
your tires should be sticky and warm by now.
we have found that on these the best pressure is between 16-18psi. you can go to 14psi but you might break axles if too much power and you have an '03
Own a Rear Wheel Drive Nissan/Datsun or Infiniti?
www.RWDNissan.com
SRTGURL's SRT-4 SIte:
www.srtgurl.com
Old 06-25-2004, 08:28 PM   #49 (permalink)
I8URVR6's Avatar
Member Number: 8924
is that 16-18psi cold or hot?
I8URVR6 is offline   Reply With Quote
Old 06-28-2004, 10:52 AM   #50 (permalink)
NIVO88T's Avatar
Member Number: 1109
that is cold, these do not warm up the air inside like a slick does so the pressure doesn't change by much, trust me...I check them after every pass!
Old 06-28-2004, 11:56 AM   #51 (permalink)
I8URVR6's Avatar
Member Number: 8924
bizzare, I noticed that they did heat the air a bit. Right now I have them at around 12 cold but after a run they're 15 hot. but I will definately test out a tad higher pressure, I love to play!
Old 06-28-2004, 12:13 PM   #52 (permalink)
NIVO88T's Avatar
Member Number: 1109
we ran them at 12psi, got lots of wheel hop and the center patch was not contacting the ground. Now I have to say that I did not say how much they went up but they didn't change much at all.
when set to 16psi they went up to 17psi or so. anything lower than that the time suffered greatly. also did the MPH..
Old 07-24-2004, 02:19 PM   #53 (permalink)
Member Number: 8030
what would be the perfered offset for 15 in rims so that i don't have to use spacers
fastsrt4racer is offline   Reply With Quote
Old 08-07-2004, 09:25 PM   #54 (permalink)
Seansurfn2's Avatar
Member Number: 9739
Quote: Originally Posted by NIVO88T
oh these tires will help...her 60' times are around 2.226-2.3's
some traction will be there now, the rest is up to her skillz!
seems ABOUT RIGHTbut i get with my drag radials on ym 2004 today at sacramento raceway 2.22,2.310 range with the 17 inch rims with only 22 psi in front tires i was in the 97 degree heat lol ran a best of 13.9-14.2ish with stage 0 3 inch turboback exhaust and aem intake but i was having a vaccum line leak agp wastegate set to 14psi drop to 12 psi at redline so ya kinda mediocre results but the 13.9 was after i cooled car down and poured water on engine and ran it right after the heat was taking its toll on my car major heat out here in cali
Seansurfn2 is offline   Reply With Quote
Old 12-03-2004, 06:11 PM   #55 (permalink)
Member Number: 11382
what size drag slicks would you run on these rota's?
03srt is offline   Reply With Quote
Old 02-14-2005, 07:26 PM   #56 (permalink)
MASSSRT's Avatar
Member Number: 23778
damn! i was psyched with that old price! (in '03)
now they're $450 a set
MASSSRT is offline   Reply With Quote
Old 04-08-2005, 02:15 PM   #57 (permalink)
Member Number: 19495
can we still get the tires for $79 a piece? I really need some 225/50/15 dr's
nazar is offline   Reply With Quote
Old 04-09-2005, 12:47 PM   #58 (permalink)
NIVO88T's Avatar
Member Number: 1109
not any longer.
Old 02-23-2007, 08:14 AM   #59 (permalink)
irishred's Avatar
Member Number: 35996
Trader Rating: (12)
will a 26x8" slick work on these 6.5" wide wheels???
-Ported AGP 50 trim, Hahn Portfueler,GreddySpecBII, Ndwings V5/ borla CB,Ported Intake by F&FP, Unorthodox camgears,DCR oil kit,HKS SSQ, lerenzo60mm TB,coolingmist W/I, Bwoody mm's, AGP 3'' intake, maddog 80%, centerforce clutch,s3 coiloverssoon Ported Head, BC S3 cams,AGP Race IC,TCS
irishred is offline   Reply With Quote
Old 03-04-2007, 01:51 PM   #60 (permalink)
NIVO88T's Avatar
Member Number: 1109
use what it is recommended by the tire manufacturer for wheel size, it is your safety at stake here...
Page generated in 0.29385 seconds with 12 queries
