Old 09-01-2008, 10:08 AM   #1 (permalink)
Member Number: 28501
Trader Rating: (17)
Default ran a 12.1 @116 yesterday
I went to the track this weekend for the the 1st time with my new setup, AGP .50 trim, act 6 puk, m&h slicks, and did ok i thought.
1st run at 21lbs i ran a 12.8 @ 113, had a 2.0 60ft, tring to slip the clutch was weird still gotta work on that.
2nd run i turned the boost up to 23lbs and ran the 12.1 @ 116, 1.9 60ft.
3rd run wasnt so good, the car wouldnt go into 2nd (syncros or something must be getting pissed?) ran a 13.5 @ 113. kinda disapointing but what do you do?
With a few more runs and a little more practice launching ill be in the 11's soon im sure.
just excited about the time i pulled,
-Jesse
I message with a lissp, sorry. <- but im not gay.
millertime is offline   Reply With Quote
Old 09-01-2008, 10:10 AM   #2 (permalink)
Super Moderator
SRT of the Month
Member Number: 39843
Trader Rating: (183)
still have the mani, o2 & dump I sold you?
congrats on getting the car together ... get the tune down & do some boost leak tests because your trap speeds seem rather low for that much boost ... at 23 psi you should be trapping 120-123mph
Old 09-01-2008, 03:32 PM   #3 (permalink)
Trader Rating: (17)
Yep, i havent boost leak tested it sence the day after i got it together over 2 months ago so could be an issue there?
with just a street tune with my safc i made 386hp 407tq @ 24psi, seemed to be about right maby a little low idk.
Ill boost leak test it this week and see what i find.
-Jesse
Old 09-01-2008, 05:15 PM   #4 (permalink)
bluebeast's Avatar
Member Number: 39695
Nice times for sure. Do you have a video of the run or a photo copy of the timeslip you'd like to share?
ROLL RACING isn't racing. It's just 2 homos speeding next to each other!
11.79 @ 118.53 S3 + bolt-on car!
BEST 60 1.68
BEST TRAP 120.60
bluebeast is offline   Reply With Quote
Old 09-01-2008, 08:41 PM   #5 (permalink)
Ant734's Avatar
Member Number: 43773
nice times, mind posting full mod list?
http://www.cardomain.com/ride/2402005/1
AGP WGA
Needswings v6
Mopar BOV
Dasmopar Map Clamp
180* Thermostat
PTP Check Valve
Fan Switch Mod
13.63 @ 104.1 98* outside temp.
Ant734 is offline   Reply With Quote
Old 09-02-2008, 01:24 PM   #6 (permalink)
Trader Rating: (17)
Ill have to get a cord to hook it up to my comp for the video, and ill get the time slip up maby tonight.
mods are, AGP .50trim .63a/r, older AGP mani, evolutioin 38mm wg, 3" dp, 3.5-4" exh, mopar intake, dw 650's, return line with rrfpr, safc, dcr 55mm tb, AGP bfmic, hard pipes, charge pipe, traction bars, h-brace, Stage 2 w/toys, and i think thats about it for drag stuff.
I get 20-23* of timing with stage 2 at 22-24lbs of boost, i can run pump 93 all day and have no kr with 11.0-11.7 afr's. I just have a street tune now(kinda crapy one at that) but ill be going back to the dyno soon to pull a little more out of it.
It was so weird launching with slicks, i figured id have to ride the clutch but didnt realize how much i would actually have to, it bogged pretty bad on each run so if i could get it down to a 1.8 60ft id be good for 11's. Next time i guess.
-Jesse
Old 09-02-2008, 01:51 PM   #7 (permalink)
BOOSTINSRT04's Avatar
Member Number: 33061
Trader Rating: (33)
Not bad! What were you launching at? Wot shifting?
S256 + F/IC tuned by Aaron@RealTune
11.88@117.9 1.74 60'
Low Boost, Low timing on pump!
Old 09-02-2008, 03:41 PM   #8 (permalink)
Trader Rating: (17)
1st run 3200, 2nd 3500, 3rd 4000, the third run i hooked almost to good, did a little longer burnout so wasnt expecting it.
wasnt wot shifting, dont want to with the new clutch tell i get a wot box. the last time i went to the track was when i killed my stocker...
-Jesse
Old 09-02-2008, 03:45 PM   #9 (permalink)
quicky4's Avatar
Member Number: 28222
good job...keep it up!
67mm Build "Under Construction"
quicky4 is offline   Reply With Quote
