Old 06-26-2009, 10:45 PM   #1 (permalink)
Rhunter's Avatar
Member Number: 36794
Default New best 1/8th mile time
Went out for a couple of 1/8th mile runs tonight. Was the first time on slicks. Tried spraying out of the hole, spun the slicks. For some reason i had a hard time getting a good burn out tonight. I looked like a total tool!!! Anwya best run was my 1st.
60' - 2.1
330' - 5.5
8th - 8.22 @ 91.79MPH
Mods:
- 03 with stage I (have diablo but ran stage 1 tune)
- 24" MT slicks on PT steelies.
- AGP WGA on PCM controlled boost (no idea what boost is set it)
- Needs Wings DP (opened)
- Stock turbo with Boomba BOV
- And of course 75 shot of nitrous
Old 06-26-2009, 10:47 PM   #2 (permalink)
conroy9940's Avatar
Member Number: 46401
Trader Rating: (114)
that 60 foot is horrible for slicks! get it down a bit mang and you'll see a huge improvement!
Pittsburgh Penguins 14-8-0 28 points
Old 06-26-2009, 10:51 PM   #3 (permalink)
Rhunter's Avatar
I know right?. Spinning out of the hole FTL
Old 06-26-2009, 10:54 PM   #4 (permalink)
j_bundrick29666's Avatar
Member Number: 49572
Trader Rating: (94)
well i cant say anything cuz my first time on slicks wasa 2.3 followed by a 2.7 60'...i was too worried about tearing stuff up but not anymore.. waiting on my clutch and theyll go back on
04 Neon SRT4 - ???WHP ???TQ
08 Caliber SRT4 - 312WHP 308 TQ (GONE)
REALTUNE FTW
AGP FTW
j_bundrick29666 is offline   Reply With Quote
Old 06-26-2009, 11:33 PM   #5 (permalink)
BOOSTINSRT04's Avatar
Member Number: 33061
Trader Rating: (30)
Work on that 60'! Are you spraying out of the hole? What was your tire pressure at, and what rpm did you launch?
Old 06-26-2009, 11:42 PM   #6 (permalink)
Rhunter's Avatar
sprayed out of the whole, Launch was somewhere around 4k. Not sure about tire presure, I forgot my gauge, I'm guessing it was about 14ish cold.
Old 06-27-2009, 09:57 AM   #7 (permalink)
Trader Rating: (30)
Try like 11psi cold, i usually run 9-11 depending on the track and launch at 4k off the 2step....but im only s3 not spraying out of the hole like you.
Old 06-27-2009, 10:02 AM   #8 (permalink)
Rhunter's Avatar
Two step is sitting in the gargage. Legion 24 and I are have been talking about installing it one of these days. I'm waiting for the Nitrous WOT cable to be tested and released.
With my lack of driving skills, I don't think I'll see my 11 sec pass this season.
Old 06-27-2009, 10:27 AM   #9 (permalink)
Trader Rating: (30)
Practice! Maybe try getting the car to launch good first, then slowly throwing the juice on it. Maybe start with a 35 outta the hole and work your way up, or even just spraying the 75 in 2-3-4 instead of outta the hole.I think with a little seat time the 11sec pass will come easily for you
Old 06-27-2009, 04:39 PM   #10 (permalink)
addictedtosin's Avatar
Member Number: 30537
Trader Rating: (115)
91-92 mph is good enough to get you in the 11s if you can get a low 1.7 60ft. Sometimes its the track prep. There are going to be days that you will spin the slicks no matter what. Def. bring the pressure down to about 10-11psi cold in the slicks. With Juice and a stock turbo you easily have 400 ftlbs at 3000 rpm or so. I would try starting at a 3000-3200 rpm and work your way up. Good mph the power is definitely there.
AGP Delta55 123mph pump low boost, 127 race gas and low boost.
addictedtosin is offline   Reply With Quote
Old 06-27-2009, 05:29 PM   #11 (permalink)
Rhunter's Avatar
Speaking of track prep, it was pretty weird. I noticed they were spaying the track, but it had some serious rubber build up. I mean serious!!! They needed to scrap it. Also, the way the water box is, you need to back into it!!!
I'll keep at it. I have a E1 sitting in the garage. Maybe I'll stay on the stocker and install the E1 over the winter.
I'm happy with the MPH, knowing there is more in it. I have not tuned the car or nitrous kit yet.
Page generated in 0.22135 seconds with 13 queries
