heres the deal a friend of mine has a 246hp extremley lightened first gen neon that runs an easy 12.9 quarter mile.it has a 2.4 with an energy head ,fast fabs long tube header ,crane #18 cams with the proper compression ,fast fabs box intake ,60mm tb ,udp,cai,cam gears ,afx race ecu and a few others i cant remember at the moment. What i need to know is what mods do i need to smoke him i have a magnaflow cat back and drop in k&n i run a best so far of 13.84@103 i have a stage 1 ecu ,agp,and quick whips intercooler on order , the 13.8 was on street tires at street weight .I am hopping to have 24x8.5x15 slicks for next season as well besides a map clamp what other mods should i add to make sure i smoke him ??
your quickwhips intercooler will also add some extra power.
There are many different combos, and you may be able to do it with less mods, but with that setup, you should easily get 12.50's if you can drive decent.
I'm running STG 1, dog bones, Das mapclamp, adj wstegate set for 21 lbs,Needswings downpipe w/ cutout closed,mopar short throw shifter, $10 catch can, AEM CIA and DR's on steelies. still only running a best of 13.40.
Got your shift light by the way, and I can't wait to put it on!
Over the winter quichwhips intercooler and aaronneon fuel return line. That should do it I hope.
[quote=moparjon]I'm running STG 1, dog bones, Das mapclamp, adj wstegate set for 21 lbs,Needswings downpipe w/ cutout closed,mopar short throw shifter, $10 catch can, AEM CIA and DR's on steelies. still only running a best of 13.40.
Ouch, one of the guys in our club is running 13.58 with only CAI, Stage 2 WGA, STS on STREET tires with a 2.0 60'!
Sounds like you need a bit more seat time, because you should get 12's easy with that setup with a good launch.
Glad you got the shiftlight, let me know if you have any problems/questions.
i ran a 13.63@105 on stock BFG's and had about 25 pounds in them with mopar stg1, mopar catback, exhaust depot catless downpipe,agp cold air, agp race i/c, agp billet wga 17/14, raptor cold pipe
I ran 13.1@105 with a 1.9 60ft on 225/45/17 Ventus K104 Street tires .. Only mods being 3" Needswing and a bleed ...
I have since added a WGA and Map Clamp . I wouldnt doubt my car could run 12.60-12.70's on slicks . I dynoed my car yesterday and It only makes 256WHP but 345WTQ ...
I have some 23.5X8.7X15" Slicks to try next time
05 OB
Mods : Stage 0 : CCA FMIC : AGP WGA : AGP Return Line : DasMopar Clamp : K&N Drop In : Walbro 255 : Needswing 3" DP : MaxxFab o2 : CMS Cold pipe w/ HKS SSQ : DIY IC Sprayer : CM Stage 4
Some Nitrous and Slicks
291WHP/374WTQ No Nitrous
426/512 Bottle Fed on 140 shot Stock IC & 02 Housing
???/??? on 180 Shot
12.194@111 No Juice 1.697 60ft
11.497@126 w/140 shot-Highest Trapping Stock Turbo in US !
look at mods in my sig, now think with slicks I am at a low 12. My boost is at 22spike falling to 16-17. These mods with slicks and mid 12's easy with a decent driver
cool if i get no other mods this year slicks are a for sure thing .I need to make use of the power i have now and get traction on the track before adding any more . Once the slicks are on bring on the parts lol
