Old 12-12-2005, 01:55 PM   #1 (permalink)
Member Number: 26931
Default Launching technique...
i hace searched about this and couldnt find an answer. What is the best way to launch our cars? I have tried the i guess you could call "traditional" way when you hold the rpm's at 2.5 and then feather the clutch while giving it gas, and ive tried just letting go off the clutch enough so the car would move on its own without me giving it gas and then just flooring it. Doing it using the first method i had wheel hop, not a whole lot because im good at feathering it and with the throttle, but i had wheel hop and it seemed like i wasnt moving a whole lot since i really had to feather it slowly not giving it a lot of gas because if you do it fast your just stuck on first spinning. with the second technique wich is the one that ive seen people do at tracks in a couple of videos it seemes to me that you kind of loose time at the beggining because it takes a little while to get going after you floor it. i didnt have anyone with me to help me check for times or for their opinion, it was just me practicing. so i would like to know which method you guys prefer, wich one you guys use for racing, not only on the track but on the streets also. thanks
2005 Orange Blast SRT-4
Mopar Stage 1 PCM
Mopar Blow-Off Valve
Mopar Cold Air Intake
Mopar Stage 1 Springs
Mopar Short Throw Shifter
AGP Wastegate Actuator
Greddy turbo timer
Greddy Catch Can w/
Greddy Bracket
TurboXS Dual Stage Boost Controller(i took it off)
Hotchkis Sway Bars
Tokiko Illumina Struts
Ghetto Mod Took off my exhaust
[live=RATMfanatic]RATMfanatic[/live]
trashkilla is offline   Reply With Quote
Old 12-12-2005, 01:58 PM   #2 (permalink)
lunchbox660's Avatar
Member Number: 10098
Trader Rating: (31)
i hold the throttle right around 18-2000 rpms, and on the second yellow light, i start to let off the clutch lightly. do not drop it, youll just spin or hop. i take it easy in 1st gear, no full throttle business, it just makes it spin. after i am about halfway thru what is lfet of 2nd, its all full throttle from there. just so you know, this technique has netted me a 2.0 60' time on street tires, so it OBVIOULSY works.
joe
lunchbox660 is offline   Reply With Quote
Old 12-12-2005, 05:43 PM   #3 (permalink)
moonrocker's Avatar
Member Number: 21392
^^^^^what he said above. also get urself some motor mounts...even the prothane inserts work well and only cost about $25. This will eliminate/reduce wheel hop........ and practice practice practice
Stage 1, E1 turbo, Stage 2 injectors, FM WGA, RPM 60mm TB, AEM SRI, Maxxfab 3" O2 Housing/DP, Borla Catback, AGP Fuel Return, Dasmopar Map Clamp, LM-1, AEM Tru Boost, PTP direct fit FMIC, Walbro Fuel Pump, HKS SSQ BOV w/ED HP, MSD 8.5mm, NGK 4306 .032, Progress Springs, Mopar STS, Greddy Catch Can, Prothane MM (Race), DC Sports Front Strut Bar.
moonrocker is offline   Reply With Quote
Old 12-12-2005, 06:09 PM   #4 (permalink)
milkman102299's Avatar
Member Number: 25193
Trader Rating: (15)
joe
Same technique here and get 2.0-2.1 every time on street tires
12.72@110 1.92 60' capitol raceway 205/50/17 faulken ziex tires 11-18--6 stock turbo
je 8.5-1 pistons .020 over-eagle H beam rods
agp standard 50 trim @23psi pump 28psi race
Greddy Profec B.-MSD DIS 2-SAFC II
PTP charge pipe
PTP 750cc-exhaust depot cold side pipe w/hks ssq
3inch intake-msd coil-stock CPU
side exit
Boomba Fuel Rail/AGP return line
Walbro 255-Dynotune 75 shot.
DCR powershift 2-balance shafts removed
milkman102299 is offline   Reply With Quote
Old 12-12-2005, 06:51 PM   #5 (permalink)
Locutus's Avatar
Member Number: 19841
Good tips in the Drag Racing forum .....
Drag Racing Fundamentals for the SRT-4
'04 Silver SRT-4, Stage 1, Mopar Cat-Back, Mopar Noise Maker, Strut Brace, STS
'81 Fiat Spider, turbo charged!
Locutus is offline   Reply With Quote
» Sponsor Links
»Garage Storage and Cabinets
Page generated in 0.17469 seconds with 13 queries
