Old 01-11-2004, 11:33 PM   #16 (permalink)
SRToc Member
jimmyssrt's Avatar
Member Number: 2544
Trader Rating: (32)
Thumbs up
Originally posted by SRT-4sjf
23x7.5x15"
Launched at 5,000rpm
Not under boost when i launched.
Did not spin grabbed HARD and bogged a little for maybe 1/2 a second.
Forgot to shift at end of track hence the 13.000 @ 102. Oh it was a 12sec pass, but i f---ed it up. Im still pissed about that. My 22"ers had no more than a 13.000 in em they spun and were to small. I ran 1.8's on them.
Wonder what kind of times youll get with 6" wide slicks?? Keep me posted if they dont spin at all maybe ill get a set.
yeah, this is the size that RedSRT4me and EvilACR (Steve K) run/ran... Steve launched at 5500 with stock PCM and was in boost...
Can't go any wider without coilovers or custom wheels... the 26s are tall and with the Kosei K1, I'll need a 1/4" spacer or so... 26x8.5 can fit with COs and spacers if need be... which a couple people on the forums will eventually run...
damn, i know how you feel about not shifting at the end of the track... i had an All Motor 1st gen ACR, which i stayed in 3rd through the traps.... my suprise in the SRT4, as i'm banging off the rev limiter in 3rd yanked it into 4th and managed a 13.88 at 100... using 205-50 (23") BFG DRs... 2.0 60ft would've been mid to low 13s... that was my only run for the day... got there late... will definately post my results after next Saturday, 24Jan, California Speedway - Night Racing
jimmyssrt is offline   Reply With Quote
Old 01-11-2004, 11:40 PM   #17 (permalink)
SRTforums Nazi Admin
NIVO88T's Avatar
Member Number: 1109
......shouldn't this have gone in Drag Racing forum?
lol........just pulling your chain....
boostaholic I launch around 5600-5800 on my 23x7.5x15 M&H's
yikes
Own a Rear Wheel Drive Nissan/Datsun or Infiniti?
www.RWDNissan.com
SRTGURL's SRT-4 SIte:
www.srtgurl.com
Old 01-11-2004, 11:42 PM   #18 (permalink)
keikeisrt4's Avatar
Member Number: 2821
Trader Rating: (-5)
keikeisrt4 is offline   Reply With Quote
Old 01-11-2004, 11:54 PM   #19 (permalink)
Member Number: 1580
Trader Rating: (13)
Why do you need the 1/4 inch spacer at only 6" wide. Does it hit the perch?
SRT-4sjf is offline   Reply With Quote
Old 01-12-2004, 12:12 AM   #20 (permalink)
FWDRacer1838's Avatar
Member Number: 2713
Where could I buy a set of rims and slicks for my srt-4...I have a set of 14in stock steelies. They have brand new tires on them. I was told i could make slicks with those. Anybody know how?
FWDRacer1838 is offline   Reply With Quote
Old 01-12-2004, 07:05 AM   #21 (permalink)
SRToc Member
jimmyssrt's Avatar
Member Number: 2544
Trader Rating: (32)
yup, it hits the stock spring perch, if i had COs, i wouldn't need the spacers. furthermore, EvilACR mentioned, the 26s grow a lot above 80mph...
Old 01-12-2004, 07:10 AM   #22 (permalink)
SRToc Member
jimmyssrt's Avatar
Member Number: 2544
Trader Rating: (32)
Originally posted by keikeisrt4
yeah, that's about average on slicks... on my ol' car, I was launching around 6000-6200 rpms I also had driveshaft.com Stage 3 axles... Now with the 2.4T and Stage 1 I won't have to launch that high... I'm going to start at 5000rpm... increasing or decreasing a couple hundred RPM with the 2-step MSD feature on the DIS-2...
One needs to launch at sufficient RPMs on slicks cause they GRAB HARD ... Otherwise, you'll bog and may kill the engine...
Old 01-12-2004, 07:23 AM   #23 (permalink)
SRToc Member
jimmyssrt's Avatar
Member Number: 2544
Trader Rating: (32)
Question do they fit?
do the 14" fit your SRT? Last time I checked with AR-24s 14" didn't fit, it would hit the whole caliper assembly... brake rotor may be too big for 14"...
Make slicks out of brand new tires??? sure, they'll be slick, just give them a lot of burnouts... anybody that tells you, you can make slicks out of street tires, is yankin' your chain... Get real slicks M&H from Jegs.com or BFG DRs from Tire Rack... Phatridz.com (Mike Crawford - Team MOPAR) in North Carolina may be able to hook you up with slicks and rims, they're around your neck of the woods... or give NEONPARTS.NET (supporting vendor - Nemo Foss) he's the "Neon Guru"...
For rims, if you're serious about getting some, go with Bogart, they don't leak... Keizer is also another brand of lightweight drag rims, however, they sometimes leak... give Nemo a call he knows the specs for the Bogart rims... The ones pictured above on my 1st gen are Keizer set, the pic below that has Bogarts skinnies in the back and 13x8 on the front with backspacing.. i ran 22x13x8 on those and yes they did stick out a little...
laters...
Old 01-12-2004, 08:37 AM   #24 (permalink)
How-To Forum Moderator
RUgoinUp's Avatar
Member Number: 181
Trader Rating: (30)
Kudo's Shelton!
Here's the run down on my 1.777 60ft (also first launch w/ slicks on a front wheel drive):
how tall were the slicks? 26x6x15 M & H racemasters
what rpm did you launch at? 4000
were you in boost when you launched? Nope
did it bog or spin? Nope, the rear view mirror flew right off!
any feedback appreciated...
14lbs of pressure, no spacer used but definitely needed w/OEM steel wheels. Using the emergency brake, I did a 1st gear burnout at the end of the waterbox.
On that run I ran a 13.3 @ 98, that was last summer in Bradenton, FL.
Mods were: Mopar S1, AGP WGA, Mopar Short shifter, MSD wires, GL springs
RUgoinUp 2 Heaven? Ever lie, steal (big or small), commit adultery (in deed or thought), use God's name in vain? Those are just 4 of the 10 Commandments, breaking just 1 condemns you to Hell. Claiming to be a "good person" won't work in a court of law, nor will it when you stand before God. If you want Heaven, admit your guilt, and ask God to forgive you solely on Jesus' death on a cross. Then love God with all your heart, and love people too.
RUgoinUp is offline   Reply With Quote
Old 01-12-2004, 08:50 AM   #25 (permalink)
SRToc Member
jimmyssrt's Avatar
Member Number: 2544
Trader Rating: (32)
Originally posted by RUgoinup
Kudo's Shelton!
SWEET!!! 60ft. 1.777
Track must have been nice and prepped, grabbing at 4k... this thread is very informative for those that are thinking about slicks...
Thanks for the tips... I'll try 4krpms as a start point and go from there... of course, every track is different, so the launch rpms will vary...
I'm sure driveshaft shop.com is coming out with heavier duty staged axles for the SRT4 soon... I had Stage 3 on my 1st gen and had the peace of mind back then the axles weren't going to give... those things are BEEFY...
Old 01-12-2004, 05:36 PM   #26 (permalink)
boostaholic's Avatar
Member Number: 1397
Default Re: do they fit?
laters...
The AR-24's 14" are too small...my 15" kosei-k1's just barely clear the rotors.
I wish the AR-24's would fit b/c that is prolly what I would be running since I already had the wheels.
I might be looking into some Bogarts or Keizers now since my slick blew out this past weekend. I'll have to wait and see!
michelle
07 GTI 2.0T
boostaholic is offline   Reply With Quote
Old 01-12-2004, 06:15 PM   #27 (permalink)
SRToc Member
jimmyssrt's Avatar
Member Number: 2544
Trader Rating: (32)
Smile Re: Re: do they fit?
yeah, kinda scary what happened with your Kosei K1/M&H combo, glad you're both okay and came away unscathed; you and Skittle. Eventually, I'll get a set of Bogarts, the Koseis will have to do for now (if only money did grow on trees, i'd plant me a forest...) EvilACR ran the K1/26x6x15 M&H combo with no failure... although, he only ran the 1/8th, his SRT has since been sold and he's in a '93 Supra now... would've like to have seen it run in the 1/4... his stats:
2003 Flame Red SRT-4
8.070@88.41mph-1/8th mile
265whp/316wh/trq
Looks like 12s easily with that 1/8th time and trap speed...
Old 01-13-2004, 11:06 AM   #28 (permalink)
Member Number: 1397
Default Re: Re: Re: do they fit?
265whp/316wh/trq
Definitely 12's.
So far my best in the 1/8 is an 8.3522@82.89 and my best 1/4 is listed in my sig.
During my 13.2 run I only cut a 8.414@82.47 in the 1/8. So Steve definitely had a 1/4 in the 12's with that mph and e.t. No doubt in my mind!
Old 01-14-2004, 11:56 AM   #29 (permalink)
SRToc Member
jasfrmn's Avatar
Member Number: 1524
I was wondering how the lauch would differ on DR's....would you burnout still? I know you wouldnt lauch as hard, right?
2003 SRT4
2004 Yamaha R6
jasfrmn is offline   Reply With Quote
Old 01-14-2004, 12:01 PM   #30 (permalink)
Member Number: 2345
Yup, still go through the burnout box, still do a burnout. Just can't launch as high up in the rpm band...
BlackDragon is offline   Reply With Quote
