Old 05-03-2008, 12:45 AM   #1 (permalink)
can't stop spinning's Avatar
Member Number: 9183
Default highest trapping stock engine/head
Just curious as to what/who is the highest trapping srt with a completely stock engine.
I want to know how my 130.32 stands up
100% stock engine, stock head, cams, blah blah blah
1st srt in Canada to get kicked off the track
can't stop spinning is offline   Reply With Quote
Old 05-03-2008, 01:29 PM   #2 (permalink)
ReDsRtKiD's Avatar
Member Number: 46248
Trader Rating: (10)
As far as I know you got it. You did this on your 3076? How much boost?
BB .50 Trim
12.8 @ 118 Traction>Me
HTA35R+EMS
11.8@114 Breaking up through 4th
60' 1.70 1/8 7.6@95
ReDsRtKiD is offline   Reply With Quote
Old 05-03-2008, 02:27 PM   #3 (permalink)
Turbolag87's Avatar
Member Number: 6491
Trader Rating: (10)
wasnt it dave from dynoworks that trapped 134 with his gt35r?
F&F Stage III 47lbs turbo
Returnline
AGP WGA,
12.38@112 with stock turbo
371whp @22 psi pump gas
Turbolag87 is offline   Reply With Quote
Old 05-03-2008, 05:36 PM   #4 (permalink)
Member Number: 9183
not positive. I know my boost gauge reads high about 2-3 lbs at an indicated 26psi, and it was indicating 30-31lbs, meaning in reality it should be 28ish. Yet my dtec said only 25.1 lbs... But I think that's all its map sensor can read up to.
Yes it was with the 3076
Old 05-03-2008, 06:03 PM   #5 (permalink)
DDogsrt461BLK 3.0's Avatar
Member Number: 32500
Trader Rating: (15)
Impressive yes, but who drive's stock anymore!!!!!
2.5L
I got's a fuel cell......................what you got?
Don't call it a comeback..........Thug Life
DDogsrt461BLK 3.0 is offline   Reply With Quote
Old 05-03-2008, 06:51 PM   #6 (permalink)
Member Number: 32196
That was with 10-1 pistons 11.1 1/4 though then it blew up.
A853 Crew (ONLY UNO)
Starting all over from stock
Mods Now04 Silver Wilwood slotted BBK slotted,slotted Rear,Windage tray+crank scraper,Dcr power shift2 clutch,Bwoody Motor mounts+trany,Stock air box mod+K&N drop in,F&F Ported ex.Manifold,3" o2 housing,My catch can+check valve,Safc Neo,Agp waste gate + ptp spring,Agp uhp,lower
^ Coming Maxed Stocker WORLD RECORD 08
Racerxvsspeedracer is offline   Reply With Quote
Old 05-03-2008, 08:25 PM   #7 (permalink)
addictedtosin's Avatar
Member Number: 30537
Trader Rating: (114)
I remember someone in the summer of 06 trapping 136 with a stock turbo and a 150 shot. I think he ran an 11.1 on that run he blew his master cylinder. I dont remember the username of the person.
R ya followin' me camera-guy??
addictedtosin is offline   Reply With Quote
Old 05-04-2008, 12:08 AM   #8 (permalink)
Member Number: 9183
you're not talking about Dasmopar are you? back from 05?
Old 05-04-2008, 07:19 AM   #9 (permalink)
MASSSRT's Avatar
Member Number: 23778
Dam, I thought 1badsrt4 had it with his 128.3.
But now that you mentioned it, I think yellowrs ran the 136, someone just bumped the trap speed thread
MASSSRT is online now   Reply With Quote
Old 05-04-2008, 11:48 AM   #10 (permalink)
Member Number: 9183
yellowrs was far from having a stock engine when he ran his 136mph
11.5@ 136mph
post #61
Old 05-04-2008, 12:56 PM   #11 (permalink)
Canada Moderator
Pablo's Avatar
Member Number: 1081
can't stop spinning, to me it looks like you got it. Now get it to hook and be the first to put a stock motor in the 10's
Pablo is offline   Reply With Quote
Old 05-05-2008, 08:24 AM   #12 (permalink)
Member Number: 58214
haha that sounds about right... my car will be up and running later this week and i'm chasing the first to put a stock motor in the 10's.... then finishing off my motor build. Can't stop spinning are you full weight.. if so you are 1 uping me... im a couple pounds lighter to say the least
megatoninduk2 is offline   Reply With Quote
Old 05-05-2008, 10:10 AM   #13 (permalink)
Hmmm, yes I see that Yellow RS has a built bottom end. Hmmm, Looks like you might have it.
Old 05-06-2008, 08:34 AM   #14 (permalink)
Member Number: 9183
only thing I did was pull out the seats. 5 min job
I'm still aiming for 10's, but the track on Friday was absolutely crap. I was spinning all the way through 2nd
If you compare this run, to my 11.2 run, I was over 5 1/10th's slower in the 330, yet I trapped 4.5mph faster.
Old 05-07-2008, 12:56 AM   #15 (permalink)
haha sounds like your making good progress i'm getting my first test and tune passes in friday but the set-up looks very good. I love these races do you have any more info on your set-up and what worked for you man.. shoot me a pm and we can talk some more
Page generated in 0.30173 seconds with 11 queries
